RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
29cc or 30.5cc head kits for baja5b
Reply
Old 08-09-2007, 03:19 AM
splcrazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 29cc or 30.5cc head kits for baja5b
want to convert my baja soon and want to get either of these kits but 29cc and 30cc is so close is would it make any differance to power or wat ? cos the 30cc is double the price of a 29cc
splcrazy is offline
Old 08-09-2007, 03:58 AM
TheFgMan01
TheFgMan01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 29cc or 30.5cc head kits for baja5b
Never owned a 30.5 but my 29cc head kit is pretty damn fast. gets to top speed very quicky!! the 29 has lots of torque..
You have a baha5. with either of these engines you may want to strethen up your drive train. You may want the 29 if you still want any kind of top speed.
Go to bigboystoysandhobbies.com and watch the vids of different largescales with different set-ups. it'll be hard to tell a difference between them watching a vid. you'll get an idea
TheFgMan01 is offline
Old 08-09-2007, 11:01 AM
fourwheeler
fourwheeler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am currently running the 29cc and it is pretty durn good.
fourwheeler is offline
Old 08-16-2008, 06:16 AM
irenaslavo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TO; splcrazy
I have also 29cc head kit but never works good, I can’t count how many spark plugs I changed, almost 2 every run, and it is extremely difficult to start. I try all possible ways to adjust the carburetor but I Failed. Could please tell me what is your needle setup.
The engine came with WT 668 I’m thinking to change it to WT 603 which is standard carburetor for Zenoah 26cc.. I don’t know if this will work? Any advice.
irenaslavo is offline
Old 08-16-2008, 07:04 AM
part-time
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: irenaslavo
TO; splcrazy
you are not fouling plugs because of the engine or carb. it could be one of these running a crappy oil or running too rich. its somthing like that. the gp290 is a great all around motor. it has plenty of torque and topend. if u went with a 30.5 u will lose some topend but u can make up for it with taller gearing.
part-time is offline
Old 08-16-2008, 06:26 PM
irenaslavo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Part time but I’m using the best racing 2 stroke engine in France but frankly the I don’t if I’m running rich or not that why I’m asking … what is the best needle adjustment for WT 668 carburetor come with CY 29 head kit. Would you please let know
Old 08-16-2008, 07:21 PM
slawhammer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a walbro 688 carb..High needle setting is 1 1/2 turn out from closed ..Low side needle is 1 1/4 out from closed...Sounds like you are fouling
plugs from oil /or bad mix ratio..try 32:1 mix.. 4oz oil to 1 gal of petro..need a good synthetic 2 stroke oil...Those are stock carb settings.. you will need to lean out a bit
I was having a low end bog with the walbro 668 carb..I just now switched to a walbro 813 carb. with modified plate,,there is no choke withis carb
it has a built in axcel pump to help low end bog for smoother eransition to mid range...I just got it installed and have yet to get it fired up..Getting late
and dark here..So I will be ready in the morning..I will let you know how it goes....AkA Slawhammer
Hope this helps..
EDIT: I also have CY29CC Engine
slawhammer is offline
