RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Engine cutting out???
Reply
Old 08-14-2007, 02:57 AM
voo2doo
voo2doo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine cutting out???
Hi RC Universe men,Bought a Beetle a while ago with a Zen 23 and it ran great for the first tank but after that it was soooo hard to re-start! I have to take the plug out and change it with another plus reset the carb back to factory[>:] It has had roughly 2 tanks through it and I cant understand it? I have an MT with a CY 26 and that runs like a dream.Bought a load of carbs off e-bay to see if that waqs the problem but the same happens no matter what.
Any advice would be much appreciated as I dont want to by a new engine .
Regards
James.
voo2doo is offline
Old 08-14-2007, 03:12 AM
Bratch96
Bratch96's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine cutting out???
air leaks, bad lines, bad filter in the tank, or maybe even a bad gasket on the engine it self.
Bratch96 is offline
Old 08-14-2007, 03:16 AM
voo2doo
voo2doo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bratch96
Cheers Bratch96
James.
voo2doo is offline
Old 08-14-2007, 07:39 AM
Earth Surfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rich carb settings will foul your spark plugs. If you would like some carb tuning instructions, shoot me a PM. The factory settings do not mean much, and some may even seize some engines, espically if modified.
Doug@ESP
Earth Surfer is offline
Old 08-14-2007, 04:52 PM
TheFgMan01
TheFgMan01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your coil could be going bad on you. ofcoarse it's happend to my truck, everythings hapopend to my truck
Like said b4, just check everything like fuel lines and gaskets. Did it have irractic idle before it cut out? could be your sylinder gasket aswell. Good luck and hope you find the problem soon so you can get back to some good ole bashing
TheFgMan01 is offline
Old 08-15-2007, 02:38 AM
voo2doo
voo2doo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cheers FG Man,is there anyway of checking the coil?going to go to town on it today and strip it down
Regards
James
voo2doo is offline
Old 08-15-2007, 02:07 PM
TheFgMan01
TheFgMan01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont know a way of checking it. usually when it is bad. on stock needle setting plugs will foul out very easily. also when trying to start your engine it'll back fire like the timing is off. those are 2 i know of personally for symtoms of a bad coil. i had a coil go bad on me with a brand new 26 Zen just past break-in, so it does happen.
