help....
SC
help....
My FG stadium bogs really bad I just replaced the horn because it started to have stripped teeth.I had to repositon the horn after I turned it off or it would take off.I replaced the horn, cleaned all the linkage, spring and fittings and the used WD-40 on it and it was fine yesterday.Today I crank it up and it bogs really bad until I am at WOT and then it seems to clear out.
VA
RE: help....
sounds like you need to clean the carb out to me... i've experienced the exact same problem and when i cleaned the carb out really well she ran just fin with no bog.. use wd-40 with the straw to spray into the adjustment scew holes and you'll a bunch of brown gunk run out. also take the gaskets out and clean in there really good and it should work out. put your adjustment screws back in at stock settings and work from there.
SC
RE: help....
ORIGINAL: 34Ford
Where in the world is Baufort, SC? I've heard of Beaufort Im up here in the mountains of NC.
