FG MT - Stripped bevel diff gear ... what caused it??
AB, AUSTRALIA
Hi Guys I have a full allum diff housing and covers and there's lots of grease in the house but some how I managed to stripped the bevel diff gears .... any idea?
Cheers
Cheers
VA
RE: FG MT - Stripped bevel diff gear ... what caused it??
I dont have an idea but mine have stripped before.. i would think it would have to do with not having those shims behind the bevels gears.. the only logical thing it could be. i still dont have those in though, mine fell out with the drive when diff cups popped out from a prior accident
what stripped, the gear it self or the shaft that goes into the gear? I have stripped my out drive shaft and just had it welded to the bevel gear. no problems since. I have found the parts to make another whole rear diff but back then parts were scarce.
AB, AUSTRALIA
ORIGINAL: motors4fun
Cougar, is it possible you got a rock jammed in the drive gears, and it mangled the mesh and it simply sheared off the teeth inside, or you had a small piece of metal come loose in the gearbox, and it ground down the gear?
I've had stuff like that happen in electric Associated RC-10 gearboxes with metal/plastic gears that loose a tooth or a chunk of a tooth.
My Feedback: (10)
Sounds like the gears are not shimmed correctly in the diff case. If the gears are not shimmed correctly, they will not mesh perfect causing them to strip under pressure.
VA
...dam im good
1 shim behimd the gear tha the diff cups enter and 1 behind the smaller gear to the left or right of it
http://j.b5z.net/i/u/2162054/i/8483-5_manual.jpg
AB, AUSTRALIA
ORIGINAL: TheFgMan01
...dam im good
...dam im good
I was looking at monstertruck pdf!
another thing that will cause severe diff gear damage is when you have a completely unlockoed diff and for some reason you hav a wheel spinning out and the other stuck in place, kinda like when working your way out of dirt and giving full throttle when only one whell spins. this is hard on the gears and a common break point.
