removing flywheel?
WA
removing flywheel?
i am installing a new crank shaft and piston in my mt5 engine and i am stuck because i catn remove the fly wheel and clutch carier any tips ?
i searched and found a usefull link for removeing the clutch carrier http://www.rcuniverse.com/forum/m_49...tm.htm#4953499
but nothing on removing flywheel any help?
ON, CANADA
RE: removing flywheel?
i think this is what your looking for.
pg 14.
http://www.rc-lode.cz/images/manual.pdf
you got the model/size of engine?
23cc or 26cc?
http://www.zenoah.net/products/hobby/hob_index.html
pg9
http://www.zenoah.net/products/hobby...G260RC_704.pdf
pg 14.
23cc or 26cc?
pg9
ON, CANADA
try grabbing it with vise grips and pulling/wiggle. its only in the guide/groove.
i've had some small engine's be very stubborn with that key.
snowblower's especialy cause of rust.
maybe some heat on the key.
ORIGINAL: mazdab2600
uuum ya the key will be hard to come out if the flywheel is still on
It's the problem to remove the bold or the whole flywheel ?
It's impossible to get the key out when the flywheel is still mounted.
First remove the flywheel and then you can get the key out.
Im not sure but it seems to me that if you have removed the flywheel and the key wont come out fairly east that it may be seized up in the journal/slot. try a mini gear puller or a c-clamp with a piece of scrap metal on the back side of the key.
