RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Synthetic And Castor oil
Old 09-27-2007, 09:43 AM
Osirisf16
Osirisf16's Avatar
Default Synthetic And Castor oil
Please, refer to those two. What is each one? And tell me which one is for baja. What are the fifferences of those two?
I hope to make a mass of answers. I want to know "scientistic" those two oils!!!
Old 09-27-2007, 11:58 AM
tmdz28
tmdz28's Avatar
Default RE: Synthetic And Castor oil
google is your friend sir.
Old 09-27-2007, 03:28 PM
Osirisf16
Osirisf16's Avatar
I search already. Is any post in this forum?
Old 09-27-2007, 04:54 PM
tmdz28
tmdz28's Avatar
hmmm
i should ask my dad for this. if you want to wait.
he is a scientist that literally formulate oil.
i will email him tonight. Just for you
Old 09-27-2007, 05:25 PM
badz
badz's Avatar
ORIGINAL: Osirisf16
its easy....
castor oil=old school...decent lube properties....all ya had to use back in the day
synthetic=new school...excellent lube properties at lower ratio's....top of line today
Old 09-27-2007, 11:07 PM
Isle of Wight Basher
My understanding is that castor oils performs better at high temps, and in lean running conditions, this is because at high temps castor oil leaves a residue that is still a good lubricant, but synthetics boil off leaving the surfaces unprotected, however this does mean that the engine etc cokes up more using castor oils.
In practice I use castor oil in a high demand applications such as 4wd, but use synthetics for 2wd.
Old 09-27-2007, 11:57 PM
Osirisf16
Osirisf16's Avatar
Ok, now i know what to use on "my" baja. But i want the scientistic one from tmdz28. I will wait...
Old 09-28-2007, 11:18 AM
tmdz28
tmdz28's Avatar
ORIGINAL: Osirisf16
Castor oil is made from castor nut (somekind of plant), it is thicker than synthetic oil. Castor oil was originally made for 2 stroke motor, because of its thickness.
Synthetic oil is produced by synthesis of oil (dont know what that really means). synthetic oil originally was made for automobile with 4 stroke motor. Since technology is more advance today, people have been able to create a thicker synthetic oil, thus also good for 2 stroke.
For your baja, i would recommend use synthetic.
Old 09-28-2007, 03:58 PM
K-Spindle
K-Spindle's Avatar
Blue marble is the bomb been using it for 5 years in 1:5 scale it flat out is the best but I am sure some others here know good oil as well.
Old 09-28-2007, 10:18 PM
JRexA
JRexA's Avatar
Castrols most popular 2 stroke racing oils A747 and the replacement XR77 actually uses a Mix of Castor and Synthetic oils.
A747 had the disadvantage, that in wet weather(Rain) the Castor oil could turn to "mayonaise" in the carb when driving.... [:'(] It also had some problems at freezing temps.
Those are solved with the XR77. Both oils are best for engines going faster than 14K RPM. Both oils are among the most popular for onroad racers in Europe.
Old 10-01-2007, 04:22 AM
Osirisf16
Osirisf16's Avatar
Mayonaise? Iouu[:'(] I'm going for the synthetic man. I don't know about you but i don't want a remote "hot dog"!!!
Old 10-01-2007, 08:05 AM
JRexA
JRexA's Avatar
The greatest advantage of the Castor based and castor/synt based are in hard tuned 23cc onroad engines, that easily revs up to 21K-22K rpm
Tuners like Alro Racing and Oddified recommends the Castrol A747 or XR77 for their engines.
From what I understand, the Castor Oil is "attracted" to hot spots, not forced away, making it a better choice in some high power applications than "ordinary"(synth and non-synth) oil.
Old 10-01-2007, 08:19 AM
Osirisf16
Osirisf16's Avatar
Gotch this
Old 10-02-2007, 03:10 PM
carpy100
a747 is used by most racers with tuned high rpm motors in the uk,off road and onroad.
Old 10-02-2007, 07:28 PM
Billyfunnyguy
While your on the topic of oils - What is better BP gas or Texaco?
Old 10-02-2007, 08:14 PM
mononpro
Look for Klotz Super Techniplate. It is 80% synthetic and 20% Castor oil. Klotz has been formulating high quality racing oils for many years. This is the only thing we use at www.largescalerc.com.
Old 10-02-2007, 09:01 PM
cyclops1970
i run the FUCHS semi synth with great liking
