FG 1/5 Comp 04 compatability with EVO 04 parts???
FL
Is it possible to replace parts from the Comp 04 chassis with EVO 04 parts (i.e. front and rear A-arms). I want to add the sway bar from the EVO 04 into the Comp 04.
RE: FG 1/5 Comp 04 compatability with EVO 04 parts???
Yes. The front bulkheads and rear arms are a direct replacement. The carbon fiber side chassis stiffeners also fit, part # 4480. I had a comp car that I upgraded to EVO specs, the only thing I haven't changed yet is the fuel tank. I know the EVO tank is more compact and centered in the chassis, but the old tank is a lower profile and might keep the center of gravity lower. But FG probably knows more about this than me so I'll probably wind up changing that soon.
NY
Luis, that comp car is definitely a good deal... Listen to Brian, he knows the car well....
Hopefully BOTH of you will come out to race on the 28th!!!!
