fg-hopups, Firehammer gears
CA
RE: fg-hopups, Firehammer gears
Well I can wait. I'll throw plastic ones on until they ship the alloys. I have two so it's doubly expensive[:@] I have plenty of steel pinions now. I'll put the FG plates on Ebay and maybe I won't loose too much.
Thanks for your help
WA
If you have any questions about the firehammer contact RCU member Slawhammer....I helped him get started wiht his Firehammer....now hes a PRO and knows where to get all parts
heres my hammer
heres my hammer
WA
ORIGINAL: mikec456
Looks like you've been pretty busy buying parts Why don't you have the alloy gear plate on?
Slawhammer was like you...I just sold him the part to help him out...either that or he had to wait till it was in stock.....I havent seen it in stock for awhile now[]
Yup... Thanks to Hellya...Like he said he helped me out...I can't thank that man enough....You may want to check my thread out....
New to 1/5 scale RC world...lots of information there from lot of different RCU members who supported my firehammer project
plus some of my own as well as some mods,plus upgrades and web site info to get parts for your firehammer.....I started like you about 6 months ago
..I have a complete rebuild on my firehammer....Hope this all helps you out....AKASlawhammer
#31
There available from here, in stock and cheaper. http://powerslideracing.com.au/index...ort=20a&page=2
The price is in aussie dollars which means it will be even less for USA guys. Email them to arrange the sale they will ship O/S.
#32
WA
CA
Wow what a great deal with Powerslide racing. I went a little crazy but what the heck Christmas is here! The two gear plates I purchased in Germany were $150 USD and the ones from PSR were only $50 USD delivered! Well I had to take advantage of the great currancy conversion rate and purchased all sorts of alloy parts. Who cares if I have to wait two weeks. Thanks for the tip!
#34
WA
Hey Hellya...
Im still in need of the flip top fuel tank lid you have on your site.. Can you still get them??
Also a few other parts.
Thanks, Chuck..
Thanks, Chuck..
#35
WI
Hellya is the man when it comes too Firehammer info, I bought tons of stuff from him... full of great info.... if you need help he is the person too contact..
#38
BC, CANADA
ORIGINAL: mikec456
Ok after spending alot of time emailing back and forth I found out the gear plate I purchased from RC-Online in Germany will not work. Although it mounts up fine. Apparently its about 2mm shorter distence between the two bearings and puts the lay shaft at an angle. I cant find the right gear plate for the Firehammer. Anyone know where I can find one. The gear plates I purchased apparently only fit FG.
I simply transferred the plate, gears and mounts from the FH to my baja and it fit perfect. (i also used fg rear brace from the large engine mount to bulkheads).
#39
CA
The problem lies with the lay shaft alignment. I have alloy fh motor mounts so my lay shaft is at 90 degrees to the gear plate. If you use fg motor mounts and gear plate then your about 2mm out of alignment on the lay shaft. I guess you could fudge a little by running the lay shaft gear at an angle to diff gears. I did find the right gear plate in australia and right now the exchange rates are in out favor. (65aus to 1.00 usd) I purchased two for under $50 USD delivered!
#40
BC, CANADA
are you using the FH engine to diff brace? i'm using the fg rear brace..maybe you'd need the fg bulks too..any how you're sorted now
here's a handy list for FH owners who want to know what fg bits fit
06011 Side guards l./r. each 1 pce. 18.59 18.59T
06023 Servo saver A/B, 1pce. 8.06 8.06T
06024 Servo saver pivot, 1pce. 4.55 4.55T
06026 Steering rods M4, 2pcs. 2.54 2.54T
06030 Steel balls 10 x 10,75, 4pcs. 8.97 8.97T
06031 Roll cage, 1pce. 14.30 14.30T
06032 Brace f. roll cage long/short each 1 pce 10.99 10.99T
06033 Wing mount, 1pce. 10.27 10.27T
06041 Pinion shaft 10 mm, 1pcs. 14.95 14.95T
06042 Brake plate and square, 4pcs. 13.78 13.78T
06044 Brake disks, 2pcs. 12.61 12.61T
06048 Steel gearwheel 48 teeth big, 1pce. 38.35 38.35T
06049 Clutch bell, 1pce. 37.05 37.05T
06050 Plastic gear carrier 60 mm, 1pce. 7.48 7.48T
06051 Dampening rubber, 4pcs. 5.40 5.40T
06061 Rear axle mount left, 1pce. 8.45 8.45T
06062 Rear axle mount right, 1pce. 8.45 8.45T
06064 Differential housing, 1pce. 16.12 16.12T
06065 Differential cover, 1pce. 6.76 6.76T
06067 Differential gearheel B, 2pcs. 35.04 35.04T
06068 Bevel differential gear axle, 1pce. 4.42 4.42T
06075 Rear upper wishbone pin, 1pce. 5.85 5.85T
06082 Gearwheel cover, 1pce. 5.85 5.85T
06096 Shock retaining screw M5, 4pcs. 6.31 6.31T
06099 Front shock mount, 1pce. 9.75 9.75T
06104 Front driving axle 55 mm, 1pce. 6.76 6.76T
06105 Wheel 1:6, white, 2pcs. 32.37 32.37T
06106 Square wheel driver 9.5 mm, 2pcs. 7.54 7.54T
06108 Off road tire stock M compound unmounted 55.77 55.77T
06116 RC-plate Futaba, 1pce. 10.66 10.66T
06135 Engine mount large, Zenoah/Marder, 1pce. 11.44 11.44T
06414 Tire inserts f.6108/6409/6411, 2pcs. 9.36 9.36T
06431 Steel gearwheel 16 teeth, 1pce. 22.75 22.75T
06540 Receiver box, 1pce. 8.58 8.58T
07088 Volume compensation f.shock absorb.,2pcs 3.06 3.06T
07089 Shock piston 2 pcs. 3.06 3.06T
07092 Spring plate 2 pcs. 3.38 3.38T
07094 Swivel nut M16x1, 2 pcs. 9.10 9.10T
07095 Adjustable ring 2 pcs. 9.10 9.10T
07102 Front wishbone pin, 2pcs. 7.02 7.02T
08092 Shock fastening pin/set collars 3 pcs. 3.19 3.19T
08097 Front axle trestle A, 96 1 pcs. 9.36 9.36T
08098 Front axle trestle B, 96 1 pcs. 9.36 9.36T
08140 Alloy plate for front axle 1 pcs. 10.01 10.01T
08348 Tank Solo complete, 1pce. 48.36 48.36T
06027/05 Ball-and-sock.joint 6mm f.M2screw thread 4.16 4.16T
06027/06 Steel ball 6 mm, 5pcs. 4.55 4.55T
06029/01 Ball-and-socket joint 10 mm f.M8, 4pcs. 6.37 6.37T
06072/01 Adj. rear lower wishbone 1:6, 1pce. 11.83 11.83T
06076/01 Rear up. wishb.thread rods r/l 61mm,2pcs 12.09 12.09T
06081/01 Ball 5/10x15 M5, 4pcs. 11.44 11.44T
06100/03 Turnbuckle right/left, 32 mm, 2pcs. 9.23 9.23T
06134/01 Engine mount small/G230 RC/Marder, 1pce. 6.76 6.76T
07070/01 Rear shock mount 97, new, 1pce. 16.64 16.64T
07087/02 Lower shock retaining, long 2pcs. 3.06 3.06T
07103/01 Front upright 12.10 12.10T
FG Part Numbers that do not work on the Firehammer
06039 Gear carrier plate, 1pc. 20.67 20.67T
06045 Brake operating shaft each 1 pcs. 7.48 7.48T
06071 Alloy gear plate, 1pce. 11.57 11.57T
06079 Rear driving axle, 1pce. 18.14 18.14T
06080 Rear dogbone, 1pce. 11.25 11.25T
06423 Gear wheel protect.f. 42/44/46/48 t.,set 18.46 18.46T
06427 Plastic gearwheel 46 teeth, 1pce. 12.74 12.74T
06428 Plastic gearwheel 18 teeth,1pce. 7.67 7.67T
06481 Alloy shock absorber 2000 long, 1pce. 28.93 28.93T
07087 Upper shock retaining, 2pcs. 3.06 3.06T
08100 Front lower wishbone 1:5, 1pce. 9.10 9.10T
06010/01 Alloy chassis Zenoah 1 pce. 128.70 128.70T
06028/01 Track rod right/left 1:6, 74mm, 2pcs. 8.06 8.06T
06066/01 Bevel diff. gear A, pluggable, 2pcs. 39.91 39.91T
06069/01 Diff.driving axle, pluggable, 1pce. 18.46 18.46T
06137/01 Bolt f. gear unit 24,5/26,5mm, 3pcs. 5.46 5.46T
08100/01 Front upper wishbone 1:5, 1pce. 9.10 9.10T
