Hitec 5745 Problems
Hitec 5745 Problems
This is the second one I have burnt up. I only had it for about 1 hour of running. I have an FG Monster Truck. When I turned on the radio and reciever the wheels automatically turn to the right. Then I made adjustements to the trims and such.
Has anyone else had this problem?
WA
RE: Hitec 5745 Problems
YEP.......thats why alot of us use the hitec 805bb with a Y harness ....plenty of power
It supplies 343 oz-in of torque and and a transit time of .14s at 6V with the Y harness (275oz-in, .19s @ 4.8V without).
It features dual ball bearings, Heavy duty Horn & Hardware Set, and it is waterproof...cost about $40
http://cgi.ebay.com/Hitec-HS-805BB-M...QQcmdZViewItem
WA
ORIGINAL: mnorman367
Are you using it on an FG? And do you use a separate power supply for it?
And no seperate supply other than the 6.0 volt required for our vehicles....the 805bb comes with the Y harness
WA
ORIGINAL: fgfever34
another questions guys???????? Are the hitec 755mg servos any good?????
thanks
thanks
Torque: 152.75 oz / 183.31 oz.in (4.8v/6v) 11.0 / 13.2 kg.cm
you are burning out the amplifier. You need to set the limits on your radio. It is why I run Spektrum. Nomadio also can be set with expos and other adjustments as well. I burnt an 805 out, but it was a bum servo from the factory, I mailed it in for service and and they sent back, and it works just fine. I use the 5745 for my throttle and disc brake servo. No issues.
My Feedback: (10)
The end points should be set between 90-95%. If you do this you will never burn out the servo. If by chance you get a faulty servo direct from the start, it will burn out right away. If you are using it for a while, then it burns out, it is not faulty, there was too much load put on the servo.
MS
Listen to Dave. You will need to adjust the end adjustments on the radio itself. Lower it down all the way and turn the wheel adjusting it as you go. I have seen them burn up from slapping side to side a couple of times.
Chris
Chris
