The REAL vs KNOCK-OFF MFG thread.
NY
With all the talk of KO's and actual legitimate cars and manufactuers, I figure it would be a really good idea for us all to have one place to post contact info and pictures of cars that are real, and FAKES.
I found this today. It is clearly a fake and not even out on the mass market yet.
Zhejiang Yongkang Easy vehicle Co., Ltd. is a large modernized corpor-ation specializing in electric scooters, electric bicycle, gas scooters, motorcycle ATV, RC TOYS and so on. It was founded in 2001. It covers an area of 50,000 square meters with US$ 5,000,000fixed assets and more than 1,000 employees.
We own 4 top-class technology processing lines of producing electric vehicles, gas scooter. Our annual output capacity is nearly 100 thousand of pieces electric vehicles. The daily output is 1500 pieces of electric scooters, 500 pieces of gasoline scooters and 100 pieces of electric bicycles. We have passed ISO 9001 and ISO 9002 quality system certification. And our products have GS/CE approvals.
Our company owns international top-class technology and equipment. The management teamis with high responsibility and spirit of enterprise. The technician are vigorous in developing new products. We have estab-lished trade relations with America, Japan Europe, Southeast Asia and so on...
Quality, price, best service is our goal to our customer. In our opinion Only you have good business, then we have good business. So customer always is the first place.
Welcome to our factory.
Member InfoRegister Date: 2007-09-27
Business Type: Manufacture, Trade
Number of Employees: 501 ~ 1000
Business Scope: Auto Parts & Accessories, Sporting Goods & Recreation, Toys, Transportation
Zhejiang Yongkang Easy Vehicle Co., Ltd.
Product Description
ITEM NO: RC CAR (YL-01)
1) Scale: 1/5
2) Max Speed: 60km/h
3) LxWxH: 817x480x255mm
4) Tire Track: Front 395mm/ Rear 400mm
5) Brake: Rear disc brake
6) Wheelbase: 570mm
7) Suspension travel: Front 95mm / Rear 100mm
8) Brake: Rear disc brake
9) Suspension travel: Front 95mm / Rear 100mm
10) Wheel type: 3 pcs with high impact nylon material
11) Drive system: HD metal gears with sealed gear box (8.382: 1 gear ratio)
12) Engine 2 cycle piston valve gasoline engine, Air cooled, 23cc
13) Torque: 1.7N. M/10000rpm
14) Power: 1.5hp / 14000rpm
15) Pre-mixed fuel, 25 (Gasoline): 1 (High grade 2 cycle engine oil)
16) FM radio system with fail safe system, radius of gyration: ¡à 200m
17) Steering servo: Hi torque water resistant 15kg. Cm with Speed 0.16sec/60 degree
18) Throttle servo: Hi torque water resistant 3.5kg. Cm with Speed 0.16sec/60 degree
N. W.: 9.20kg (engine weight: 2.00kg)
G. W.: 12kg
Carton size: 875X525X325mm
20ft/40ft/40HQ: 177pcs/367pcs/458pcs
Trademark: OKBUGGY
Model: YL-01
Another one you say ?
sureee !
BANG BANG... oh look ANOTHER ONE..... by the same Co.
*Although I DO like the jeep body...
[B]
Product Description
ITEM NO: RC CAR (YL-02)
Engine Type: 23cc DZY23SC
Fuel Type: Gasoline/2 stroke lubricant oil¡ª25: 1
Remote device: 2-channel(Futaba-OEM)
Speed: 80km/hour
Range: 45 minutes
D I M E N S I O N S / C A P A C I T Y
Length: 700mm
Beam: 530mm
Height: 350mm
Package Size L / W / H: 80x57x42cm(CA02 is 80x57x46cm)
G. W. / N. W.: 15kg/11kg
Qty. /Container: 180pcs/20'GP; 380pcs/40'GP; 445pcs/40'HQ
O T H E R
Colors: According to your need
Decals: ORION. Trade decals (OEM is welcomed)
Distance: 480mm(front and rear wheel)
Tire Size: 190mm
Toolset: Standard
Characteristics
* 23cc gas engine Which made by our factory
* Have gear box, four gears, have centrifugal clutch
* Assembled Body Base
* Engine with X-power Japanese Carburator (Waibro)
* Japanese NGK spark plug
* Pull start engine
* With muffler and air filter
* Two wheel drive
* Rear helical teeth differential drive
* Over capacity of oil tank (40 minutes / one tank)
* Over length spring shock absorber
* Hard aluminum base
* Rear Wheel Disc brake
* Japanese two channel remote and 15kgs large torque direction servo
Trademark: OKBUGGY
Model: YL-02
[\B]
Product Description
1) Scale: 1/5
6) Wheelbase: 570mm
G. W.: 12kg
Trademark: OKBUGGY
Model: YL-01
sureee !
[B]
Product Description
Speed: 80km/hour
Range: 45 minutes
Length: 700mm
Beam: 530mm
Height: 350mm
O T H E R
Tire Size: 190mm
Toolset: Standard
Characteristics
* Pull start engine
* Two wheel drive
Trademark: OKBUGGY
Model: YL-02
[\B]
RE: The REAL vs KNOCK-OFF MFG thread.
The jeep and the truck would probably have part support, in the form of Duratrax, or Carson, or XTM, or Smartech. I'm assuming that the parts are the same as all of the other Smartech vehicles though. Hobbythek also has alloy parts for these and some of the parts are interchangeable with FG. As for part support from those guys above that "manufacture" these, highly doubtful.
MD
I have the 26cc clone of the bigfoot truck and it is a money hole. The steering servo stripped after 1 tank of gas. The shell broke apart on me the first day after one tumble. U will also strip out gears easy. Needs alloy motor mounts large and small and steel pinion and spur. I only paid 600 bucks to my door for it so I cant complain too much. Ive done other upgrades also but might as well buy a better vehicle outright.
CA
ORIGINAL: Mastino Mike
FL
I like the first one, It will have great part support, I looks like it uses all the same parts as the baja B5, I think its a great deal
IL
A better idea than buying a knock off or buying the real deal would be to buy all the parts individually and pieces together an awesome rc made from all upgraded parts for one money.
Now who here will dare take on the challenge of putting together some complete parts lists.
And how come I've never seen a knock off of MCD trucks????????????
Heres a baja 5b nock-off?
http://lowriderjunction.com/store/pr...roducts_id=745
they also have others..
maybe they are just trying to earn some money i dont blame then for selling nock-offs (they dont claim it is a baja 5b at all)
