Electric - Large Scale Thread Discussion
NY
I was tooling around in this forum, and there is not a big LargeScale Electric thread. There is a bunch of stuff out, from 100.00 NewBrights to 3000.00 bigboy racers.
So, lets post pix and discuss how we can hop tehm up or make them fast like the gas cousins !
CARSON Schattenjäger (Shadow Hunter) CE6-B
1:6 electric powered offroad model, pre-assembled with brushless motor and speed controller included.
The double layer chassis is very stiff. The mounting locations of batteries and motor result in a low center of gravity for high cornering speeds and a neutral behavior over jumps. The a-arms and the shocks are the same as the Carson Comanche, no proprietary things here and the same adjustability to change your setup. The car is fully ball raced.
16 NiMh cells (2 x 8-cell packs) with a brushless motor provide very good performance. The speed controller has forward, brake and reverse!
Technical details:
no fuel smell
very quiet
easy handling – charge the batteries, plug in and go
wheels with 15 cm diameter
brushless motor included
speed controller included (forward / brake / reverse)
approx. 60 km/h top speed
approx. 10 minutes run time
weight RTR approx. 7,5 kg (~ 3 kg less than a comparable gas powered car)
strong acceleration
incredible throttle response
Technical ..
Chassis CE-6B
Length: 740 mm
Width: 430 mm
Wheelbase: 475 mm
Motor BE5-brushless
Speed controller E5-Car 100
Top speed ca. 60 km/h
Weight: ca. 7,5 kg (RTR)
Battery pack: 16 cells
Content of delivery :
Car with body shell, assembled RTR
with brushless-speed controller
no steering servo included!
Accessories needed:
RC-system (2-ch or up)
Jumbo-sized steering servo
2 x 8 cell battery pack (9,6 Volt/ Sub-C)
Batteries for the rc-system (TX and RX)
Charger for the all batteries
appropriate charging cords
Car, assembled with motor and controller: € 512.00
Battery pack for Schattenjäger
8-cell battery pack for the car above, 3600mAh, NiMh . You need two packs to run the car.
High current version with 2,5mm² cable.
€ 61.50
Oh, and my neighbors will be greatfull as well because the Electric power is quiet at night, and also ECO-FRIENDLY as it does not use any gasoline from them damn Iraquiez....
Technical details:
no fuel smell
very quiet
strong acceleration
Technical ..
Chassis CE-6B
Length: 740 mm
Width: 430 mm
Wheelbase: 475 mm
Motor BE5-brushless
Accessories needed:
€ 61.50
RE: Electric - Large Scale Thread Discussion
ORIGINAL: Dave ESPI
Can you show us a big electric here to start.
NY
F:1 FORMULA 1 WORLD CHAMPIONSHIP
Radio Control 1:4 Scale
Available in BLUE/BLACK/WHITE/YELLOW
http://aycu30.webshots.com/image/374...9715781_rs.jpg
http://aycu25.webshots.com/image/347...0534975_rs.jpg
http://aycu25.webshots.com/image/347...5292758_rs.jpg
http://aycu21.webshots.com/image/365...2823060_rs.jpg
Factory Assembled R/C Monocoque Type Frame
Front and rear double wishbone suspension.
Coil spring damped suspension system.
High performance super type electric motor.
Front and rear rib tires.
Highly detailed poly carbonate. Body shell.
INCLUDES:
F1 CAR
REMOTE CONTROL
RECHARGEABLE BATTERY PACK FOR CAR.
8 "A" SIZE BATTERIES FOR REMOTE CONTROL.
CHARGER
ANTENNA
INSTRUCTION MANNUAL
EVERYTHING COMES IN THE BOX SO JUST OPEN CHARGE AND ENJOY PLAYING WITH IT.
1:4 R/C F1 Racing Car Specifications
Fully assembled 1:4 scale
LCD - Remote control unit, which shows direction on LCD screen.
Sturdy monocoque type frame
Front & rear pin spike tires
Highly detailed polycarbonate body shell
Age 8 upwards
27 or 40mhz frequency.
Retails for 199.00
also:
1:4 4WD LG SCALE R/C MERCEDES BENZ CLK DTM RC CAR -
RED/SILVER/BLACK/BLUE
It's a high-quality item that is simply HUGE - it's just shy of 4 feet in length! This factory assembled R/C car has TWO high-performance 550 type electric motors because it's 4WD - that's right, all 4 wheels are driven.
Other features:
§ Highly durable & detailed polycarbonate shell. The body varies in thickness from 3/32" to 1/8". It will not break easily and looks like the real thing.
§ Coil spring dampened front and rear suspensions.
§ Headlights illuminate when going forward.
§ Taillights illuminate when going backward.
§ Two forward speeds. It has an initial speed then a maximum speed when the trigger is pulled all the way. Maximum speed is 14MPH.
§ Front steering adjustment.
Specifications and what’s included:
§ Product Dimensions: 45"L x 18"W x 13"H
§ Box Dimensions: 47.8"L x 20.3"W x 14.4"H
§ Heavy-Duty Battery: 12V, 4500 mAh (5HR recharge time with approximate play time of 20 minutes)
§ Charger: Input = AC110V, 60 Hz Output = DC 12V 800mA
§ Transmitter/Controller: Gun style with 9V battery included
§ Frequency: 27MHz or 40MHz
§ Instruction Manual: English
INCLUDES:
F1 CAR
REMOTE CONTROL
CHARGER
ANTENNA
INSTRUCTION MANNUAL
Age 8 upwards
Retails for 199.00
also:
Other features:
ORIGINAL: Dave ESPI
INCLUDES:
F1 CAR
REMOTE CONTROL
CHARGER
ANTENNA
INSTRUCTION MANNUAL
Age 8 upwards
Retails for 199.00
also:
Other features:
INCLUDES:
F1 CAR
REMOTE CONTROL
CHARGER
ANTENNA
INSTRUCTION MANNUAL
Age 8 upwards
Retails for 199.00
also:
Other features:
Very nice trucks man, but with a 12V battery they probably don't go over 20MPH right.
NC
Scroll down the bottom of the page to see a brushless HPI Baja 5B
http://www.finedesignrc.com/ct-hpi-hotbodies.asp
RCNuts has an electric on-road car, I think its a Harm.
1Troy7
Thats sweet. Brushless would be insane.
Dave,
Thats Carson is nice, the others look more like toys from KBToy store or ToysRUs.
1Troy7
Dave,
ORIGINAL: T I G
1Troy7
Dave,
1Troy7
Dave,
That car has a Lehner 8HP Motor. 8HPPPPPPPP
NY
MCD is working on an electric also. they made mention of it in another thread here on RCU.. ( looking for it now)
It was a thread talking about the recient hobby show... had a vide also with a wheel blowing off it in the yard doing roundabouts
http://www.rcuniverse.com/forum/m_63...tm.htm#6362793
TIG, yeah, but stil 1/4 scale is UNHEARD OF for toys. They are set up junky, but with some mods, and a few after market parts, they could be a seriously viable "play toy" that does like 40mph
NEWBRIGHT
Based in Hong Kong, New Bright has been around since 1955 and produces radio control and remote control vehicles, train sets, and electric toys and accessories. Ranging in size from a big 1:6 to a hand-size 1:24 scale, in addition to cars, trucks, and jeeps there are several boats and motorcycles. New Bright Toys include officially licensed Chrysler, Dodge, Ford, and Chevrolet products.
The ready-to-run New Bright RC toys are usually full function with forward/reverse and left/right steering, use rechargeable battery packs, and often come in multiple colors and frequencies for each style of vehicle. Some models have working lights, realistic engine sounds or music, spinner wheels, high & low gear selectors, and 2 speeds. Many of the larger models have 4-band selectable frequencies. Most toys are for ages 8 and up.
1:6 Scale Cars and Trucks: In 2005 the International CXT [ Guide Review of CXT ] in red or silver dominated store shelves then the Hummer began showing up over the next several months. Other big New Bright vehicles include cars like the Ford Mustang GT, Nissan 350Z, and Porsche Carrera GT and trucks like the F-150
LOL
A lot of us FG truckers are snagging the bodies from these and slapping them on our trucks
NEWBRIGHT
LOL
My Feedback: (10)
I have a fg baja that is currently being converted to brushless. I am hoping to have ti done by the spring. We are testing out the setup and will be available soon through the shop
NC
ORIGINAL: rafa26
ORIGINAL: T I G
1Troy7
Dave,
1Troy7
Dave,
Dave ESPI
Not RC but funny.
http://videos.streetfire.net/video/a...db0189a30d.htm
FG,
lets see some build pics. That shold be pretty sick
CT
Item Specs Price
HPI 1/5th Scale E-Baja
Brushless Electric Conversion Buggy - Lehner 8HP Motor
- 150Amp 4-10S Brushless Speed Control
- 10S 5000 Mah 30C Lipo Battery
Item Specs Price
How much for this baby ?
NY
e-baja ?
W T F ? !!! [X(] when the f did they come out with that ?
ARGH !
I would SOOOOOO buy that !
EDIT: here is the inside of a New-bright car rear end
Would be sooooooo easy to slip a big dif in there and a modified motor.......
ARGH !
NC
e-baja ?
W T F ? !!! when the f did they come out with that ?
The fg does not come electric, there is another company making the electric conversion.
Do you have a link?
Esc's are the only thing holding me back. If i could find a reasonable priced durable esc i would convert a 1/5 in a heart beat.
My Feedback: (16)
TX
I'm still new to large scales, but I really cannot imagine not having some kind of 2 stroke engine sound coming out of one of these things...
It just wouldnt feel right...like someone told me before..."running electrics is like watching watching tv with the sound turned off.."
ORIGINAL: turbodremz23
It just wouldnt feel right...like someone told me before...''running electrics is like watching watching tv with the sound turned off..''
But each to their own I guess.....
I tried using an electric lawnmower once.
I broke out in a rash all over my body and had many years of therapy afterwards....[&:]
I'm ok now though.
*Twitch twitch*
that baja looks scary [] lol. any video?
anyone having problems with a speed controller, ever thought
about going back to a "mechanicall" speed controller? the old school
ones operated by a servo?
i must say i am facinated with big electric stuff. just the power and
size. quite brutality.... muahahaha.
seriously though some footage of that baja would be sweet.
