what size piston and head
Hi
my question I have just bought a engine that needs a new top end it is a cy 28.5 crankcase and 2mm stroker crank can anyone tell me what size head I can use with it thanks
UT
RE: what size piston and head
ORIGINAL: hunterz
Hi
Hi
ORIGINAL: badz
The crankcases are all the same, the top ends and crankshafts are what changes. You have a 2mm stroker crank you can use any top end made actually, the choice is wide open, if the cylinder isn't cut for the +2mm of clearance needed for the stroker crank you toss on a copper shim, but you can still use anything pretty much made
ORIGINAL: hunterz
Hi
Hi
thank you
