Baja engine comparison.
Other tah the stock engine on baja rtr,to upgraded a new engine which type of engine is suitable to be mount on?there are alot of aspect to be look on like Thinner piston ring
Modified cylinder Wider transfer port Crank case with wider ports Crank case has more material so it does not blow out base gaskets as easily Improved intake manifold etc.A powerful race motor wif modified carb & air filter.
my mind is tinking abt G260RC from oneil brothers racing.
Thinner piston ring .8mm
Modified cylinder
Wider transfer port
Red spark plug cap
Plz advise
Modified cylinder
Wider transfer port
Red spark plug cap
Plz advise
Moderator
RE: Baja engine comparison.
Im not sure I understand your question. The stock SS engine is a 26cc Chung Yang, branded as a "fuelie" for HPI, and its not a bad engine. The modded G260RC you're looking at is nice, and is compatible.
