Breakin procedure help!
VA
Well I have a Baja on it's way. What break in procedure should I be doing? What oil-fuel ratio should I do for break in process? I will be using Klotz Techniplate Oil...
UT
RE: Breakin procedure help!
ORIGINAL: jtnktz
Thats what I thought but foxy said otherwise....
ORIGINAL: badz
there is no break in required, mix is 25:1
ONE TANK or about half an hour runtime, just take it easy, don't baby it, but don't give it long WOT runs either, then on the second tank or toward the end of the first, tune and let her rip. This is what all the hobby shops and racers I have spoken to say.
As for rings and seating, that's not the only factor. (Real) cars have pistons and rings and they have to be run-in. It's not so much a question of necessity as a sensible precaution to let the oil work it's way round the system, all the parts bed in, etc. It's not a break in as such, it's just a good idea to take it easy on the first tank.
VA
Alright, so during the first couple tanks I should run it at 25:1. Then what ratio after that? I thought you don't change ratios as it was like nitro and their percentage (in a way).
does no harm to take it easy for the at least the 1st tank... personally i ran mine in over 2 to 3 tanks only because i was used to doing it with nitros. Some say you need to change the piston ring after run-in etc! , again i havent & had no probs.
the 1st couple of tanks my MB did seems sluggish, but on the 3rd she was ready to rock!
there is u can feel wen u drive the baja.if no difference den y are there all kind of petrol wif different grade?even my r1 using 95 n v power theres a different
Whatever you say dude... Like I said I haven't tested it, but the gas is not designed to make a diffrence in 2-stroke single cylinder engines, it's designed to make a difference in 4 stroke multi cylinder engines with 100 times the displacement.
MB, CANADA
ORIGINAL: wan6176
MB, CANADA
ORIGINAL: wan6176
maybe coz in singapore is diferent i guess lol
IL
ORIGINAL: clubin
NO, there is no difference in power, all a higher octane does is lower your combustion chamber temperatures. Some people take placebos and feel better. LOL
ORIGINAL: wan6176
I feel that Shell gas runs better than Phillips 66 gas. So, if he says he can feel a difference, I believe him, but, there's no telling what the real reason for the quality difference is.
well bro im living in singapore and we have 3 kind of petrol here not to say shell,esso or mobil.each petrol got their own price.we have 3 category for petrol that is 92,95 and 98.
the cheapest is 92 where seldom ppl here use except old car n bikes that are going to scrap.medium usage is 95.and the expensive one is 98.if i use 95 full tank on my r1 i can use til 220km.if i use 98 i can use till 260.And most of the time i run my bike above 12okm/h.thks bratch
MD
ORIGINAL: snoking16
so can u use regular car gas mixed at 25:1?
Just something to think about - Although running in isn't all that important, the first ring on a new engine doen't last as long as a replacement according to various engine tuners I've spoken to.
Mike
Mike
