Baja Carb
FL
Baja Carb
By replacing my stock 5b carb with a Walbro WT-813 High-Performance Carburetor for Zenoah / CY Engines
will I gain very much performance...Top-end or bottom..Both..?
RE: Baja Carb
ORIGINAL: hayabusagreg
RE: Baja Carb
ive got the wt 813 carb with accelerator pump and using it on my modded up TS induction crankcase with 29cc and stuffed crank , i have to say its pretty good it solves the lag problem the flap hole size is alot bigger compared to stock , but it has no choke , you might have to open and close the throttle to vent it then pull the cord to start it . Ive also used it on a stock engine and yes there is a noticible differance , feels like the engine runs better
FL
RE: Baja Carb
Same here...somewhere I read that I should keep the stock carb...? But I have a CY 30.5 with pipe and thought it could use more fuel...? I dont know ..calling Shawn today and see what he think`s also going to ask if I should get a reed valve ?
RE: Baja Carb
The idea of the bigger carb is to get more AIR into the engine. Of course if you get more air you'll need more fuel but that's easy. I have a stock carb on my 30.5 also. ESP has been building these motors for a while so I'd prob go w/what he says.
