Weight in front end of baja 5b?
[8D]Hey, I own a Baja 5b and I like to jump it a little bit, but I find that when jumping it, the nose end seems very heavy in the air and the buggy likes to land front first. But if you gas right at the end it seems to make up for it. Anyways, my question is if anybody can tell me whether or not adding these TeamGoNads disc brakes to the front end would make a significant difference for weight in the front end for jumping.
Here is a pic of the brakes.
http://www.radiocontrolzone.com/showthread.php?t=240960
Thanks[8D]
Thanks[8D]
WA
RE: Weight in front end of baja 5b?
if you hit the brakes with it in the air the front end is going to dive down...especially if you ad those front brakes...the tires act like gyros...so if you blip the throttle in the air it will help raise the front end...im not sure how much but thats how i did it with the smaller scale stuff. i dont think it works as well as the smaller scale stuff but i think it helps a little.
It works much better witht he smaller scale stuff. The weight of the chassis and parts in comparison to the weight of the tires on a large scale, means you have very little attitude control in the air. Shame. There's a vid of an FG monster beetle doing backflips on oneillbros site, but it's low speed and it's using the 'wheely' effect to get the the rotation. Still cool though.
ORIGINAL: fire_racer17
Thanks[8D]
Thanks[8D]
Thanks guys....I have adjusted the shocks (more front pre-load and more back damping) and it stays nose-level over the small jumps I hit. Now, I have to check on front brakes.....hydraulic, cable, etc........any recommendations?
