My strictly unofficial Baja 5B SS thread
I am starting a Baja 5B SS build thread. Didn't find one, and this beautiful RC really deserves one here on RCU.
As I am a very busy person I may not be able to finish the RC in a flash, but I would really like comments and post from other builders so we can enjoy this cool RC together. Owners of Bajas as well as any other poster is welcome to comment.
Also I would really like to see some body paint jobs if you guys out there have some ideas as to how I should paint mine. I have 3 clear bodies. Please post your pictures
EDIT:
There was a 5 page thread already made a while ago as the mod made me aware of.
I certainly did not mean to barge in the door as the MOD kindly put it
There are also many ohter threads dedicated large scale RCs so if you guys out there feel strongly this thread wont be needed then let me know.
The Baja 5B SS is certainly not brand new, but I imagine build threads have been started of old RCs before.
I've also renamed the thread as the MOD didn't appreciate it being an Official thread. It is certainly strictly unofficial.
My intention is to post great pictures of this car first as I build it and later as I drive it for any posters appreciate.
EDIT:
RE: Unofficial official Baja 5B SS thread
The most important part. The power plant. It's a bit more significant than the Tamiya silver cans
HPI packed the engine smart. It was crammed into a cardboard box totally immersed in air filters [8D]
There are already a number of helpful threads about this car, here are some of the more memorable ones which may help you out...
Baja SS first sighting... http://www.rcuniverse.com/forum/fb.asp?m=6166477
A random SS discussion... http://www.rcuniverse.com/forum/fb.asp?m=7415510
Yet another random SS discussion... http://www.rcuniverse.com/forum/fb.asp?m=7349899
And another... http://www.rcuniverse.com/forum/fb.asp?m=7054534
SS V RTR as a base model for modding... http://www.rcuniverse.com/forum/fb.asp?m=6749939
Dave's 5 page build thread... http://www.rcuniverse.com/forum/fb.asp?m=6757935
Picture threads...
http://www.rcuniverse.com/forum/fb.asp?m=7009349
http://www.rcuniverse.com/forum/fb.asp?m=6448629
And the daddy of the large scale picture threads...
http://www.rcuniverse.com/forum/m_2489993/tm.htm
Picture threads...
Oh and by the way, the build isn't tough for most modellers, but the car gets MIGHTY heavy toward the end of a 9 hour build session!!
Be liberal with the threadlock and the transmission grease.
ORIGINAL: Foxy
RE: My strictly unofficial Baja 5B SS thread
You will want some red, but mostly blue. Engine bolts which go through the bottom of the chassis, I would recommend red, and the same for the clutch bell screw, but it's your choice. Blue will do the job in those areas, but may need regular checking. Bear in mind, anywhere you do use red, will need a lot of heat to get the screw out again. I consider a small pentorch essential equipment for baja disassembly.
Dedication..... (joke)
ORIGINAL: frumpy
Just a quick comment here,Lunchboxer how the hell do you amass 30,000+ posts since 2006?Do you ever sleep?lol
ORIGINAL: Foxy
ORIGINAL: Foxy
Upgrade what you break. First breakages will likely be dogbones and if you jump, shock shafts. The car is actually a really solid RC, it's tough to break in all but the most serious accidents.
Your first hop ups/extras should be a set of outerwears (one for the filter and one for the pullstart cover), and a set of axle extenders, as the rear rims rub on the arms at full suspension compression and extension. Not only do they solve this issue, but the extra stability from the wider stance is very helpful in preventing rollovers when cornering, which is why I personally also recommend the front set as well as the rear.
Apart from that, as I say, upgrade as you break. Fully assembled the car will weigh about 12 kilos and travel at around 70kph. Pretty awesome, which is why a lot of people invest in engine cut off failsafes too, as a runaway Baja could do serious damage to property, and people.
get the turtle racing upper brace and then add also a diego front chassis brace . this will help on frontal crash ahh and a ds bumper. and be carefull of your bank account cause this is addicting
I'm going away for the extended weekend but just had to check out the tires and rims. I'm told the Baja 5B SS is a relatively simple and fast build. The bead locked rims though, take time if you screw all hex screws by hand. I would recommend using only hand power too as it is easy to tighten too hard.
I've shot some pics with some DF03 Avante Mk II wheels for comparison to those as new to large scale as I am.
Yeh, when I change the tires, I bring the wheels inside and do it while watching TV or something, otherwise I'd kill myself from the boredom. lol
PS. Nobody said it was a fast build. But it is easy.
ORIGINAL: Foxy
ORIGINAL: Foxy
Here is a very cool video from the twin Baja project by Brice_arnold
http://www.youtube.com/watch?v=Uk8X_gEsMU4
I don't think you get a cooler mod than that.
Buy a set of Proline badlands as soon as possible (if you still have the pic of my baja, those are the badlands on the rear), and an appropriate set of front tires too (like the dirt buster front blocks for dirt running).
Tanks of fuel to wear away a set of rear badlands through regular dirt running... hm... there's something I never really considered. I suppose it depends how abrasive the dirt is. I'd have to guess, and say, I dunno... 50? As for fronts, they'll last a loooooong time. My new front 'block' pattern dirt busters happen to be sitting on my desk right now, so I snapped a pic, here it is... I really like the way they make the front of the car look so much more aggressive, and on loose surfaces, I'm sure they'll be a hell of a lot better than the stock front ribbed tires.
By the way, nearly forgot, hostilehobbies MX tires are totally insane on the block pattern, they have the most aggressive tread you have ever seen on an RC, check them out. They also last a long time, but can be tough to find in stock (everyone snaps them up, every batch), and are pretty pricey, but probably worth it. They're more for soft ground running I suppose.
ORIGINAL: ArildS
ORIGINAL: ArildS
The manual says to use 'Rubber Cement' to glue the front tire foam together. Do you know of any other type of glue that can be used?
ORIGINAL: Foxy
Have any Baja 5B (and 5B SS) owners noticed that the tires smell quite strongly? I am talking about the stock tires here. Mine smell so strongly of hydrocarbons that 'the wife' have ordered me to put them in the garage until they 'sublime' to a more manageable smell level.
LOL. Can't do anything but laugh about this, but they do really smell quite strongly.
ORIGINAL: Foxy
Didn't notice this post. You should use rubber cement, it's easy to find. It's that glue that smells great, that you use when building plastic static models. You know, the clear stuff? It's good cos it will retain a little bit of flexibility, and slightly melt the insert material to itself, but if you really don't want to go buy a tube, I guess you could get away with regular CA (superglue).
