Motor questions on CY26
MN
Couple questions, whats the HP rating on a stock SS Baja with the hpi pipe? I'm looking at getting a new headkit for mine and was wondering how much i'll be gaining. Also if i do get a head kit thats a 29cc is my stock carb still going to work or do i need to replace that?
RE: Motor questions on CY26
I would strictly guess but it is probably about 3 HP plus whatever the pipe gives you ....Carb will be okay ...they are pretty much interchangable with all the CY motors,,,,,
Hope this helps
BC, CANADA
If your thinking 29cc go for the cy gp290 28.5cc I put this head on my 5b and it pulls wheelies no problem now, loads of power. I also have the billet cy 29cc "headkit" and It's ok but the 28.5cc is better in my opinion. And yes your carb will work just fine. Good luck
