BELT DRIVE OR CHAIN DRIVE BAJA5B'S
Is it possible if moddified to run a belt drive or chain drive system instead of the stock spur and pinion ? Personally i would like to see a thick strong rubber belt drive system inplace of the spur and pinion
RE: BELT DRIVE OR CHAIN DRIVE BAJA5B'S
how many times in a year do you replace your rubber belt drives on your industrial or home electric saws ? i think that a setup like this will run better and can handle more abuse from 7 HP plus engines
My Feedback: (-2)
i most definatly will stand up better for the power, but reversing the rotaion will prove to be not worth it. what about puting some metal gears in. you can pretty much make the drivetrain bullit proof with some meety bones and robinson gears.
Banned
It could have been a more efficient design if HPI implemented it in the beginning since the gearbox could have been designed with just 2 gears instead of three so less driveline loss. As it is to make it would you'd have to redesign the gearbox as well.
WA
ORIGINAL: splcrazy
As soon as belts get wet, they slip...make sure its enclosed or cogged [sm=thumbup.gif] how about a mini tranny and driveline
FL
Been thinking the same thing...maybe something like a snowmoble set-up...when the drive pulley increases rpm the spring in the pulley could be replaced with a hard or soft spring making the launch adjustable...similiar to a 8000rpm spring verses a stocker...as far as the reverse rotation issue a 2nd pulley (idler) with another belt to change rotation making gear ratio`s unlimited !!!
I agree with splcrazy I think this would be a smooth ,Lt wt. low mantainance set-up with alot of gear ratio choices.
FL
OK...been driving by that place for month`s never could understand the sign..?? POHS OTUA ???? Thought it was a Mexican Resturant ???? Thank`s
Banned
this is what im talking about something like this instead of having the pinion and spur gears , i would love to have a setup something like this to replace pinion and spur gears, to something similar that looks like ive got in the pics
ORIGINAL: splcrazy
FL
This is a set-up I have on my old mini bike...Almost like a torque converter..as the engine speed increases the pulley closes belt tighten`s and the power is transfered to the rear
FG's released 4x4 Marder uses a belt with teeth on it. Looks pretty beefy. It will be interesting to see some video and reviews on it.
