Boost Bottles?
RE: Boost Bottles?
Lunatik did a dyno test on another website where he tested these, and at best, it did nothing, but at some point, the engine actually lost power. i am sure if you shot Lunatik a PM he may post the results, or they may actually be up on his site.
My Feedback: (16)
TX
RE: Boost Bottles?
I went back and looked at some other threads about these and decided not to bother with them...
I guess with the ones I have used on my nitro cars, I had seen some gains, but they were for specific engines, not a "universal" application
My Feedback: (16)
TX
RE: Boost Bottles?
i would assume that it would make some difference if there was a supercharger or turbo small enough...but even a small IHI turbocharger is bigger than the engines..
there would have to be a small scale version similar to the RB Innovations superchargers..
RE: Boost Bottles?
NOS has been found to be extremely effective, but makes tuning a nightmare, since you want one tune for when the NOS is on, and another for when it's off. These are still in development.
I don't think a turbo is really feasible, but I've often wondered why there are no superchargers. I think basically, the answer is that a 6 hp top of the line engine already puts out too much power for most of our cars to stand, so there's actually no need to add more.
One of our members, Monaroman, did some testing on a DIY NOS system, and posted videos, quite effective.
http://www.youtube.com/watch?v=QaSjoo6uKPU
http://www.youtube.com/watch?v=iIhK_UlJ6nY
RE: Boost Bottles?
If you look at how a 2t engine works, it is basically already a compressor (supercharger). Air/fuel is drawn into the crank case, the piston compresses it on the downstroke, and when the transfers open, it is blown into the combustion chamber. To add essentially another compressor (supercharger), you have to consider a couple of things. What is the supercharger going to do with its charge while the intake is closed? There is no plenum to store it, so you would need to add a "storage plenum". Now you need to find correct volume and so on, which would be virtually impossible since the volume (pressure) the supercharger generates would change based on RPM, so now add a blow off valve (more complexity, more money). So if we solved the first set of problems, how do we keep the added pressure from blowing the cylinder off? There are now a/c 4 bolt heads (and even our 4 bolt marine conversions), but even those can have base gaskets blown out without an added supercharger.
I personally don't see this as a viable means of adding HP to a 2t, not to say it cannot be done, but I doubt that the added benefits would be worth the cost to do so.
Banned
RE: Boost Bottles?
yeah i know a guy who tried a boost kit. From a stand still it'd bog for a while then suddenly take off as it should, totally killed low end throttle responce and gave no other noticable improvement, wasn't an issue that could be tuned out either. Was to time & money.
WA
RE: Boost Bottles?
Anyone whos tried this says it works... Nos kit...I would like to see a dyno on this Lunitic (hint hint)
http://www.oneillcart.com/cgi-bin/sh...ry%3D%26sku%3D
Video http://www.oneillbrothers.com/rccar/...sterbeetle.wmv
My Feedback: (16)
TX
RE: Boost Bottles?
I looked at the no2 kits from RB Innovations. didnt know there was another company that offered one.
MY question about these kits is, are they actually using nitrous oxide, or co2 cartridges? cause if it is no2, when all the cartridges are gone, you need to order more right? I have easy access to no2, and even have a few sneaky pete bottles that are refillable and arent very big at all...
I might have enough parts to build my own system, but would have to rig a mount to my KM for the bottle and solenoids..then calculate the size of jetting to use to not blow the engine up, or run it too lean...
anyone know what kind of jetting is used for the rc nitrous kits? voltage? etc...
My Feedback: (16)
TX
RE: Boost Bottles?
i think my CY may be the test dummy for this...not the Zen...
mabey the CY will come in very handy..
once its rebuilt and broke in i will start some bench testing with pictures and video..
RE: Boost Bottles?
ORIGINAL: hellya
WA
RE: Boost Bottles?
this thread might help http://www. hpibajaforum.com/forum/showthread.php?t=16422&highlight=nos+kit (remove the spaces)
My Feedback: (16)
TX
RE: Boost Bottles?
yes I have seen that..been watching his progress for sometime now.
but I have everything needed, and even have a couple small solenoids that can operate off a lower voltage instead of 12v.
I was thinking of using the circuit board from an old servo, and placing leads where the servo motor should be and running the solenoid off the servo's pc board. I think the voltage output should be enough to trigger the solenoid and give a nice shot..but I need to test the voltage output vs. the solenoid.
WA
RE: Boost Bottles?
Here a dyno for this engine with and without nos
Complete 26cc heli engine fitted with nitrous oxide system. This is a serious engine, complete brand new 26cc heli engine(never been fitted in a car, only dyno tested) fitted with a professional nitrous oxide kit. Dyno tested up to 12 bhp!.
Basically a complete motorcycle nitrous kit, including a 0.5kg nitrous bottle, solenoids(wet system), range of jets etc(additional 2.5bhp upwards…). The nitrous system alone costs over £500
Custom made nitrous controller pcb, engine rpm input with throttle servo connection, automatically operates n20 system at full throttle and between 8000 and 18000rpm.
Obviously this engine cannot be used in any racing series!, but as a fun/demo engine fitted in a monster truck or similar, it would be outrageous!.
Banned
RE: Boost Bottles?
Unless your going to fit a wet NX kit then there really is no point other then to run extreemly rich one minuite then to have some power the next. The real deal will be to run normal then run really powerful.
Dry kits are only suitable for modern cars with oxygen sensors that can richen the mixture when they detect more O2, which the NX will fool the sensor thinking its detected - unfortunatly our hobby engines don't have oxygen sensors...
RE: Boost Bottles?
how are the solenoids activated and does all the stuff nessasary to complete the install come complete ? do yous all reakon i should put on a nos kit on my already 7to 8 plus HP baja engine lol
