Changing cylinder gasket on FG Monster!
I am going to change my cylinder gasket on my FG MT (Zenoah 260) and just wonder if there is something special to consider when doing this? Or is it just that easy to unscrew the 2 cylinder bolts and take the cylinder off and change the gasket?
MB, CANADA
RE: Changing cylinder gasket on FG Monster!
You'll have to remove the engine from the FG and blow everyting off with compressed air
remove fan shrowd there are the 2 bolts to remove and you are good to go. Easy job though.
What makes you think it needs changing?
ON, CANADA
Just remember when tightening the bolts to do one then the other and back and forth from the head bolts so you get a slow even pressure on the head gasket.
ON, CANADA
Go to fasteddy's on youtube and watch the 9 part engine rebuild tutorial.
http://www.youtube.com/profile_videos?user=TeamFastEddy
