Baja5b SS to 5T hop-up HPI parts list ?
NY
The 5T is a RTR. I have a 5bSS already.
Anyone kind enough to post all the different parts and HPI stock #s up here in this thread for all us who want to giantize-out out buggies into trucks?
THanks in advance
Do the community a service !
* and be loved by all
THanks in advance
RE: Baja5b SS to 5T hop-up HPI parts list ?
I'm just gonna get the Proline kit Dave,cheaper and looks better,add a DS steel bumper and "voila",a Trophy truck at a much lower cost....
NY
ok, so for those of us who do NOT go to that forum due to personal political reasons of epic retardation between companies and moderators...., can someone C/P the list from that thread here ?
thanks.
thanks.
ORIGINAL: Dave ESPI
thanks.
thanks.
I've done a few research and here's a list of ALL parts you need to convert from 5b ss to 5t and vice versa:
5b to 5t:
80598 SFL-10 MG Aluminum Final Gear
87280 Aluminum Steering Arm for HPI SFL-10 Servo
86482 Drive Gear 19 Tooth
85441 Roof Guard Set
86975 Roof Plate
85419 Body Mount Set (Side) 2x
85247 Stone Guards (Side)
85246 Engine Guard
85425 Under Guard for 5T
85447 Body Stiffener For Baja 5T-1 Truck Body
85249 Spoiler For Baja 5T-1 Truck Body
85423 Bumper Guard Set
85417 Body Mount Set (Front/Rear)
85421 Bumper Skid Plate Set
3331 Front Outlaw Wheels Black (120x60mm/-4mm Offset)
3336 Rear Outlaw Wheels Black (120x65mm/-10mm Offset)
4804 Inner Foam (190x60mm)
4818 Molded Inner Foam MS (190x70mm)
4437 Desert Buster Radial Tires HD Compound (190x60mm)
4440 Desert Arrow Tires HD Compound (190x70mm)
7563 5T-1 Painted White Body
7564 5T-1 Painted Black Body
*85402 Rear Suspension Arm Set (if you want the updated versions) 2x
*86483 HD Drive Gear 19 Tooth (replace 86482 if you want to run HD gears)
*15483 High Flow Muffler (if you don't want to run the SS pipe)
5t to 5b:
85443 Under Guard
86486 Drive Gear 20 Tooth
87430 Roof Plate
85442 Guard Deflector Set
85452 Wing Set
86690 HPI SS Tuned Pipe Set
7560 5B-1 Blear Body
4736 Mounted Dirt Buster Rib Tires M Compound On Black Wheels (front)
4737 Mounted Dirt Buster Block Tires S Compound On Black Wheels (rear)
That's probably all. Just trying to help out those who are going to do conversions. Feel free to add parts that I may have missed.
NY
Thanks AC, you are my hero this week
Looks like I have to repaint a new shell now for my SS and make it a beastly crawler
ORIGINAL: Dave ESPI
