813 carb. issue
MB, CANADA
813 carb. issue
I just got my 813 carb today, I went to install it and there isn't any where to hook pu the throttle, did I order the wrong carb? Or is there a quality controll issue with this one?
right is the 813 and left is the 603.
this is the carb I ordered
another view, left is the 813 and right is the 603
RE: 813 carb. issue
yup you did order the right carb you need the modifed linknage arm . http://www.oneillbrothers.com/rccar/...linkagearm.htm
RE: 813 carb. issue
I see... Cyclops got you covered there..I use a 813 with the mod shaft..awesome carb..little picky to adjust ..but once there it is great..
AKASkawhammer
AKASkawhammer
RE: 813 carb. issue
ORIGINAL: kidd
you ordered the wrong carb. you need the one with the modified shaft. go back to ddm's site and you'll figure it out.
remember modified shaft!
CA
RE: 813 carb. issue
Yep, you ordered the wrong carb. You ordered DDM part AV521 without the modified shaft and you needed part number AV522 with the modified shaft. Since you already have the carb without the modified shaft you could just order the modified shaft Cyclops mentioned.
[link]http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4722/.f[/link]
[link]http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.852/.f[/link]
MB, CANADA
RE: 813 carb. issue
All figured out, thanks for the replies guys. When I was reading through the info it clearly states it to be a replacement upgrade carb for the Zen. I thought the modified shaft was just that modified, I was not aware that there were diffenent throttle linkage hookups.
It's all good though, I ordered the modified shaft and a 27.2cc bb kit with a 2mm stuffed stroker crank.
Thanks again guys.
Thanks again guys.
RE: 813 carb. issue
Glad you got it sorted out..You will love the head kit & crank..I have the 29CC head kit and stuffed crank..That motor is a screamer...
Did you ask about the head porting?..To be done.........813 will work better when ported..But you can run ok with out porting the head..
AKA Slawhammer
AKA Slawhammer
MB, CANADA
RE: 813 carb. issue
Yes, that's all done this is the kit I bought.
http://www.oneillbrothers.com/rccar/...achined_wc.htm
it should haul.
it should haul.
