RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
help engine wont start
Old 11-07-2008, 12:35 PM
greed1
Default help engine wont start
just got the new radio going and 10min in to the first the engine dies
it has spark
why is it not going
thanks for the help
Old 11-07-2008, 01:09 PM
Lars from Norway
Lars from Norway's Avatar
Default RE: help engine wont start
Did it run fine before it stopped?Even if it has a spark,it might be a weak spark that dont "survive" inside the cylinder due to the pressure.Try to change the spark plug before you rip it apart,also check that the stopswitch is off (i mean,not pushed in and holding itself there)
Old 11-07-2008, 03:25 PM
mbe301
mbe301's Avatar
What engine in what 1/5 scale?
Old 11-07-2008, 06:25 PM
greed1
it is a 27.2cc oneil i think in a FG Marder
spark is fine replaced with a new plug
striped the engine down tonight and found this
could this be the cause of the engine not running if so what do i need to do to fix it
thanks graham
Old 11-07-2008, 06:47 PM
clubin
clubin's Avatar
Yep' that'll do it, you'll probaly need a cylinder and piston.
Were the c clips in the piston? If they were it looks like it got too lean.
The engine was too lean.
Here is one of mine
Old 11-07-2008, 06:48 PM
toez71
greed1
i had this happen only 2 times on me and both were hi speed runs( full ffin tilt) and both had less than four tanks, i think these zens need more brekin period b4 they are run wide open, im not sayin its your problem just tellin u what happen to me, these cyl have a beter lining than cy and therefor take longer to seat the ring and breakin, i no otheres will disagree but im puttin in my 10 centsnow im pretty sure this is y some builders cut the upper end down on zen pistons to give them some type of relief when they expand,talk to sean hes a good guy to deal with hope things work out for u,,
Old 11-07-2008, 06:54 PM
toez71
hey clubin what a shame is that the new dark soul cases? to bad bro sorry to see that,that was a nice setup u had there,guyz these zens need to be broken in a litle more b4 they are beat to the redline, [X(]
Old 11-07-2008, 06:55 PM
greed1
which c clips do you mean
also how can i tell if it is or was an oneil 27.2cc engine and do i need to conact them for a replacement
i just keep pouring money in to this thing will there be a point were the money stops going in and you end up with a bullet proof car
thanks again
Old 11-07-2008, 07:08 PM
clubin
clubin's Avatar
ORIGINAL: greed1
thanks again
The c clips I was refering to are the ones that hold the piston pin in the piston.
You'll need to check the crank shaft and see what it is, a 27.2 has a 2mm stroked crank. If it is just a stock crankshaft you can put a stock 26cc Zen cylinder and piston on that'll save you a bunch of money.
That failure I posted above was due to a crapped carb!
Keep pouring money into it and I don't think it will make the car bulletproof. At least mine still break with all the expensive mods done. lol
Old 11-07-2008, 07:21 PM
greed1
if it is the 27.2 can i just add this cylinder and piston and it will go again
i will check the c clip tomorrow
http://www.oneillbrothers.com/rccar/...bbk_ported.htm
Old 11-07-2008, 07:34 PM
clubin
clubin's Avatar
ORIGINAL: greed1
http://www.oneillbrothers.com/rccar/...achined_wc.htm
This is the kit that is probaly in your engine, you will absolutely need to split the case and see what crank is in it.
Old 11-07-2008, 08:59 PM
Dave ESPI
Dave ESPI's Avatar
oh man that sux. [X(]
Try breaking in the engine with 25:1 ratio and use real 2 cycle oil, not synthetic. Don't go over 1/2 throttle and just be smooth on yout on/off throttle transitions and not any fast starts and stops. A good "warm up" tank, then let it cool, and then run the second tank with more middle to upper range throttle with a few drawn out near full throttle runs. Third tank, after the engine is warmed up....leter rip ! after 4th tank, reduce to between 28:1 and 32:1 oil and if you want , switch to AMSoil Interceptor synthetic or stick with the regular oil.
Ive broken in 3 engines sofar this way and they all run strong as hell.
Old 11-08-2008, 03:07 AM
greed1
i bought it second hand and the engine was already run in about 3 or 4 tanks through it
it is going to be another week or two befroe it is running again [&o]
Old 11-08-2008, 08:22 AM
greed1
c clips were still on the engine
do i need this one
or this one to get the same engine
or are they the same one with out the crank
Old 11-08-2008, 09:16 AM
toez71
greed1 if u no for sure u got the +2mm stroker crank in there all u need is this
http://www.oneillbrothers.com/rccar/...d_machined.htm
its not hard to see if u look at the side of your crank in the engine it should be there printed stroker +2mm
even if this scoring has still happen i would pull it and clean out the caseing and bearings of any debree that has accumilated in there just to be safe,
Old 11-08-2008, 09:55 AM
greed1
yes it does have the 2mm stroker that will save me some money then
