DIY Carbon Fibre MCD Gear Guard
I've been running with out gear guard for a bit now, & though its time to cover them up. What to use will decided to try my hand at some Carbon Fibre work.
So here we go.....
First time to make mould
RE: DIY Carbon Fibre MCD Gear Guard
Well it’s been an early start this morning but is all finished,
Attempt 01 &
Had a little trouble of getting it out of the mould…..
Attempt 01 &
Got stuff from East Coast Fibreglass Supplies.
https://www.ecfibreglasssupplies.co.uk/store/index.php
Carbon Fibre 200g Plain weave
Polyester Gel-Coat (inclusive of catalyst)
Polyester Resin (inclusive of catalyst)
PVA Release Agent - 100ml GLOSS
It's got a couple of air bubbles you just can't see them, they are on the bottom, but it was a lot of hard work to work them out.
Hey Borler1863,
I've got a MCD 4x4 Stadium Truck conversion from Largescalerc (Innovative Hobby Products), its great,
I've been busy making parts, why pay for them.....
how did you make the mould i would like to make some for my marder
thanks graham
thanks graham
ORIGINAL: nzkiwi1975
Greed1
You need to use plaster-of-Paris or casting plaster to make you mould, work out what you want to make,
Then see how you can cast mould so that you will be able to apply Carbon Fibre weave,
I applied PVA Release Agent first then Gel-Coat, then Carbon Fibre weave & Resin.
It took a bit to get out of mould. You may want to try & make mould in two halves.
Good luck.
Good luck.
