RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
kamitiro 4x4 kit for fg?
Reply
Old 01-10-2009, 02:19 PM
steveteal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default kamitiro 4x4 kit for fg?
Hello,I just purchased the Kamitiro 4x4 kit for my FG Monster Truck and would like to know if anyone has and picks on how to mount the steering servo and receiver box?.Also if anyone has any build tips or had any problems.Thanks for any info.
steveteal is offline
Old 01-10-2009, 02:22 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: kamitiro 4x4 kit for fg?
From the looks of the Kamitiro web site of the overhead chain drive system, it looks like the servos and electronics remain where they are, no need to relocate anything.
If smoething must be relocated, the instructions would tell you, moreover, the kit would have additional hardware to make the relocation possible.
SAVAGEJIM is offline
Old 01-10-2009, 02:24 PM
steveteal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is the chain drive system.Where did you see the picks?
Old 01-10-2009, 02:39 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I only say them in Kamitiro's own site, but I also found these links in RCU. Scroll down some for some pics w/o any servos, but a single steering servo will fit
http://www.kamitiro.com/iv3/cms?SID=...AID=46&LANG=en
Check out this link, look at post #5. It is for the overhead belt driven version. It looks like you have to go single servo only, forget using dual steeing servos.
http://www.rcuniverse.com/forum/m_54...tm.htm#5466594
However, a fellow RCU member has had bad lick with the plastic structural members:
http://www.rcuniverse.com/forum/m_71..._1/key_/tm.htm
When I say structural members, I dont mean strutural as part of the RC structure, but structural as part of the supports and braces for the Kamitiro kit itself. Kamitiro should have made these structural parts out of alum or other materials to withstand the engine torque stresses. Too much plastic set too high exposes those parts moments that exceed their material strengths.
Old 01-10-2009, 02:42 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: steveteal
You have to move your steering servo over as in photo #### 3 ......you have a place for 2 servos in the tray... use the left mounting side
..............................and now the bad news.............................................. ......
hellya is offline
Old 01-10-2009, 02:53 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
^ Ah! Look at that! They totally redesigned the rear structural mamber to carry the forward 48T & and rear chain sprocket! A Steel reinforcing piece to elimitate the breakage of teh rear structural member!
Steve, make sure the Kamitiro kit you have has this steel part for the reat plastic member. If not, call Kamitro for the upgrade part and let them know you have the older all plastic rear member. Otherwise, as Hellya has just shown of the broken pieces, the all plastic rear structural memeber will break just like in those pics.
BTW, thanks Gasjockey for giving us info and providing pics of the problems you had with your Kamitriro kit.
Old 01-10-2009, 03:10 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh yea you will need the hitec 5745 steering servo for the kit....805bb wont fit
ID:	1107752   Click image for larger version
ID:	1107753   Click image for larger version
hellya is offline
Old 01-10-2009, 03:22 PM
steveteal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thankyou for such fast reply's really appreciate it.I hope I didn't make a mistake by buying this kit.So I have to move the steering servo towords the steering box?.
Old 01-10-2009, 03:23 PM
clubin
clubin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am supprised to still see these kits around. That sure is a complicated way to ge the front wheels to pull.
clubin is offline
Old 01-10-2009, 03:34 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: steveteal
Towards the stock reciever box
hellya is offline
Old 01-10-2009, 03:40 PM
speedy.d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh the humanity!, wow, now that is carnage at its finest. was the damage caused due to the sprocket unscrewing its self from the shaft. if so couldnt you turn the threads down so that you have enough threads to mount the sprocket and then put some type of block wiht a grub screw in it to hold it in place?
speedy.d is offline
Old 01-10-2009, 04:54 PM
mooman007uk
mooman007uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hellya
looks like you used the belt drive alloy bits and kept the chain drive, I was looking at this conversion when i first bought my baja but the bad rep and losing my 2 speed put me off, i did was wonder back then if you could cross the two kits to make one that would work..i guess you can...any problems since you fitted the alloy?
mooman007uk is offline
Old 01-14-2009, 08:01 AM
fgbasher
My Feedback: (10)
fgbasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YOu do not have to move the servo, you can use spacers on the bottome of the servo tray between the servo and the tray. THis will lower the servo under the chain and you can still use the access holes on the chassis if you need to.
fgbasher is offline
Old 01-14-2009, 08:26 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point. But how far down is too far down? If you remount the servo too low, it will be in a horrible alignment such that the steering linkages will bind and stuff.
Old 01-14-2009, 08:34 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hellya
ORIGINAL: steveteal
Another thing: Be sure to redo your linkages to the steeing servo saver block piece. You will have to make use unequal length arms from your wervo such that the steering block servo saver piece will be centered even with the steering servo to one side. The right side arm to the servo saver steering block will have to be the shorter arm. Worse, since the arms are unqual length, one side will turn at a diffent rate than the other side, so thre will be some binding at certain arcs of the servo's operating arc.
Maybe this binding will be small, and the plastic bits will, well, be mechanically plastic such that they will strain in a plastic state to absorb and correct that binding.
Old 01-14-2009, 09:06 PM
FGmyzer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
stay away from this kit. We have seen many problems with this kit in German RC forum
FGmyzer is offline
Old 01-14-2009, 10:33 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: FGmyzer
Same problem as Gas Jockey's chain drive problem? If he gets the one with the steel plate for the structural memeber, the possibility of that structural plastic failure would be almost eliminated.
