wet coil
wet coil
does this happen to any of you guys out there that insist on running in less than perfect conditions? when i run in wet weather/ snow this is usually how our trucks die out we never know when its going to happen but it does. we can bring them in take hair dryer to the recoil cover and within minutes its back out to do it all over again. here is a link to a vid showing it as it happens
http://www.youtube.com/watch?v=Yst9EKXUy3w
My Feedback: (-2)
RE: wet coil
i dont think their motor gets wet. but i have checked you tube and their are some funny vids of guys swimming back to the beach towing the boat with one hand...lol
RE: wet coil
good reason, swimming huh? i will stick with walking over and picking mine up! although sometimes it gets so wet around here i have considered putting pontoons on it!(or skis)!lol
RE: wet coil
I would try putting something around the manual kill switch ( balloon ). This could help keep it running a bit longer. I've never had this happen, but also never got mine that wet either. Just something to try. I would guess it to be the kill switch more than the coil ?
My Feedback: (-2)
RE: wet coil
see, im thinking that its more of the coil. water gets pulled in from the bottom by the fins and just coat the magnets for the coil... the worst place that has ever happened was on a frozen lake. it was starting to melt and had some big puddles. even though the ice was still 12" thick, it made made me nrvouse walking all the way out their
RE: wet coil
Coating the magnets for the mag set-up with water will not stop the spark. Magnetic force will go through water & still trigger the ignition system. It almost has to be the plug wire letting the spark out early, or the manual kill switch being shorted inside by water. Reguardless, I would do some water proofing & see if it gets any better. This problem would be hard to determine for sure.
My Feedback: (-2)
RE: wet coil
ya, i guess that was silly of me thinking magnets dont work under water... i was just thinking it wasnt the kill switch couse my 5b doesnt have one. and it still dies, just like his
RE: wet coil
Here very soon it's time to get them out for some fun. We'll have to make it a group effort & see how many we can get going at once. Sound like a great time for sure ! We'll see if this problem happens to more of us. Maybe we can actually solve this mystery ...
RE: wet coil
that works, my buddy with that old firehammer has got it doing wheelies on demand. for as old as that truck is it rips! the jetpro and 26 does alright on that thing!
MB, CANADA
RE: wet coil
Seems more like a fuel tank vent got plugged, the snow plugs it rite away, I have been doing the snow thing for months now, that is the only issue is the tank vent, I don't think it is ignition. If by some chance it is get yourself some de-electric grease and coat the spade connectors on the coil and kill switch.
RE: wet coil
ORIGINAL: speedy.d
its like hitting a light switch. what do the boat guys do?
Yeah, I too have seen too many guys with boats stranded out in the middle of a lake or whatever. I even knew a guy who rigged an a-frame with hook made of coat hangers and mounted on the bow so that he could fly a heli out with a noose and line and hooc the a-frame of the boat and tow it in.
The most common reason why boats wind up stranded is either dead batts and the failsafe shutting them on or running out of gas
RE: wet coil
ORIGINAL: kryptonite5b
RE: wet coil
i have treid a different coil, and it stll happens. my buddied firehammer seems to die more often than mine. im going to try insulating around the plug wire.
RE: wet coil
If you find a solution, please post and let us know.
I myself will daydream on this matter more, if I can come up with a solution or mod, I'll give a description.
RE: wet coil
Is that a new Coil?..You might want to put on a better coil wire...when you do also use heat shrink at the coil to seal it..will
also help from pulling loose....Who knows when that coil wire was made and how long been sitting on a shelf...there subject too
pin holes....Just a thought...You can get a silacone cover for the kill switch...use die-electric grease on all your connectors.........
AKAslawhammer
AKAslawhammer
MB, CANADA
RE: wet coil
I'll say it again, it is more than likely the fuel tank vent getting plugged. That has happened to me many times, but I have NEVER had a issue with a coil.
These picture's aren't that bad, you should have seen today. lol
RE: wet coil
ORIGINAL: clubin
This vent, is it an area of low pressure or high pressure? If it is low pressure, I can see how snow gets into it. If it is high pressure, the snow will simply blow away.
RE: wet coil
if you notice in the vid the engine dies right at the big splash, i can run in snow without much problem. it is puddles that kick my butt.my first move is going to be in the kill switch department. if that doesnt help i will look at the tank.
when i do the kill switch i will also insulate around where the plug wire screws in
RE: wet coil
When you talk of running in bad conditions check this race out. What an interesting 24 hours !
http://www.youtube.com/watch?v=-5hME...eature=related
http://www.youtube.com/watch?v=XCuy7...eature=related
RE: wet coil
ORIGINAL: bsrman14
Rust on the coil and magnito could be the culperate.
In his case, there isnt enough rust to make his RC stop, it is shorting out for sure.
