2 speed , onroad off road
can someone tell me what the difference is in the 2 speed kit for the onroad and off road.
is it just the gears that are different? can any 2 spped kit fit on any fg model?
RE: 2 speed , onroad off road
On road 2 speeds are usually clutch type for softer engagement, think of it as a stock type granny transmission.
Off road 2 speeds are usually cam type for instant engagement, think of it as a built with a shift kit racing auto transmission.
All 2 speed trans that Ive seen are specific for a particular application.
so are the gears the only different? so everything else will work like hub carrier shaft ect... will fit for both car and truck?
My Feedback: (10)
The are basically the same set up with the exception of different gears and the gear carrier. The onroad carriers are smaller than the off-road ones.
BC, CANADA
onroad gears are 42 and 40 offroad are 46 and 44 everything else is identical, the smaller 47mm 2nd gear hub is an option for the 38 t spur
