RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
tuning baja 5b
Reply
Old 01-31-2009, 08:44 PM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default tuning baja 5b
have baja 5b with 29 cc motor and had walbro 813 carb on it. had no problem tuning it but the 813 broke so i put stock carb back on and cant get it tuned. it dies out or when i hit the gas it stays reved up to long and the comes back down and dies or just stay at too high of an idle. any help
bruce5385 is offline
Old 01-31-2009, 09:28 PM
mooman007uk
mooman007uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: tuning baja 5b
sounds like you may have an air leak...did you use new gaskets when you swapped carbs?
mooman007uk is offline
Old 01-31-2009, 09:33 PM
associatedrules
associatedrules's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just had the same exact problem. I found a damaged o-ring on the low speed needle of my carb. You most likely have an air leak.
associatedrules is offline
Old 01-31-2009, 09:53 PM
BadClownCrawler
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ya check the orings, gaskets in the replacment carb. also check the carb manifold. the stock plastic ones can warp/crack and cause a leak. you can get it idleing and spray wd 40 directly at the seams and stuff around the carb, see if the idle change, or if the motor stalls when your shooting the carb, keeping aware of where the spray is hitting the carb. i can point you toward a leak.
BadClownCrawler is offline
Old 01-31-2009, 10:03 PM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks ill change all gaskets and o rings and give it a try
Old 01-31-2009, 10:05 PM
associatedrules
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the off topic, but do you know of any bash spots in central Florida for 5th scales to run?
Old 02-01-2009, 09:39 AM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no but want to meet people to run with
Old 02-01-2009, 09:41 AM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pm me and ill give you my number
Old 02-01-2009, 09:43 AM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the base gasket between the gugg and lower end of motor had a blow out so that could be part of the prob. ill let you guys know when i change it. thanks for all the help
Old 02-01-2009, 09:46 AM
looker2756
looker2756's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you've found your problem. Cylinder gasket will definitely cause the problem you described. Easy fix.
looker2756 is offline
Old 02-01-2009, 04:10 PM
bruce5385
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the gasket was the prob fixed and runs great thanks for all the help
Old 02-01-2009, 05:37 PM
looker2756
looker2756's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 29cc stroker is a pretty high compression engine. I ended up going copper to eliminate the same issue. Glad your fixxed !! Nothing worse than a broken / not working car.
