Integy axle extenders for the BAJA
WI
Does any here have the Integy axle extenders for the HPI baja? I seen that they come in silver,orange,purple,green,blue.. If you have them can ypu post your experience on the EXTENDERS only!!!!!! thank you...
GA
RE: Integy axle extenders for the BAJA
I think ArildS is running them. I am like many others and will not run anything Integy from poor experiences with there products and POOR customer service.
CO
I have them on my Rampage but have not run them yet. The quality seems good. The wheel nuts have o-rings in them to keep them from coming loose.
WI
ORIGINAL: Z_Pilot
Dark Souls are 10 times better
Does any here have the Integy axle extenders for the HPI baja? I seen that they come in silver,orange,purple,green,blue.. If you have them can you post your experience on the EXTENDERS only!!!!!! thank you..
WI
ORIGINAL: 46u
I'am lookingf or personal EXPERIENCE only on these... not OPINIONS...
AZ
DarkSoul has a new Version out, that uses the solid pins instead of the screws. Integy hasn't stolen that design yet, so I can't say from personal experience whether theirs are better or not. Well, I have no personal experince with them anyway, since I wouldn't support that type of company.
GA
I think you should buy a set and try them then you will be able to voice your own opinion. I do not have experience with the particular item you are talking about but do have experience with other items they sell. Buy them and if you do give us and update after a gallon or so.
WI
ORIGINAL: 46u
LA
ORIGINAL: hndaman1
I just did order them....I will post pics of them when they show up..These are going on baja #2
ORIGINAL: 46u
Take care buddy
Bryan
ORIGINAL: RAMTech-HBF-LSF
WI
My new extenders came already on Sat(thats was fast I just ordered them thurs night) well anyways. they are well stout in design,and these are MACHINED not casted either...I also like the way they use and o-ring inside outer nut ... these are worth the money IMO... I also added my little .75 caps to the ends of them to keeps dirt out of them I'am been using these caps on the front axles on the 5bs since the 5b came out...
Here you can see the end cap
here is just a pic of the little caps I use
WI
ORIGINAL: bryan70546
Hondaman are those the xtra wide extenders.
I do not know. .I can get you the exact offset if you want me too?and can compare them to the Vertigo ones I have on my other car?
it does not say on Integy website either for the fronts or the rears
http://www.integy.com/st_prod.html?p...61&p_catid=126
http://www.integy.com/st_prod.html?p...69&p_catid=126
WI
They just look like the ones I ordered they pretty wide for the rear. But thats a good thing
you know what they say a good wide rear end is not a bad thing
LA
ORIGINAL: hndaman1
