ADA 4 bolt kit
MB, CANADA
ADA 4 bolt kit
Well, I bought one installed it and ran it. I am very happy with the install and it is sure nice to have more options for my 4 bolt case.
I am running a 13:1 compression dome with a 2mm stroked crank.
http://www.davesmotors.com/s.nl/c.88...t.A/id.5687/.f
MB, CANADA
RE: ADA 4 bolt kit
ORIGINAL: toez71
nice please be sure to post a clip,id like to hear what it sounds like...that dome looks mint,very clean,is the cyl part ada to??
This in my opinion is the best 4 bolt kit available, I ported the cylinder copying another ported cylinder I had. It is a great engine.
It sounds quiet with the Samba, but if you are interested I will take a short video for you.
RE: ADA 4 bolt kit
Very nice! I dont have my G270 yet, but how does the G270 run? Before you put the head kit on it that is.
That headkit looks great on your truck there BTW. [sm=thumbup.gif]
RE: ADA 4 bolt kit
Looks real sweet my friend...Nice to know there are other choice's...You should have great torque from that new topend...
As always you do fine work on your RC Units....Best to you on you adventures.....Slawhammer
RE: ADA 4 bolt kit
if your looking for a different 4 bolt set up you should look into a RCMK 254 top end with a DS head cooling , i bought a RCMK for my boat with adjustable timing for under 250 the top ends are just over 100 i think with more meat to open up if adgressive porting wanted to be done but unported its rated at 5 HP . just another option is all
nice mill you have though
MB, CANADA
RE: ADA 4 bolt kit
ORIGINAL: cyclops1970
I wanted to get away from the marine cylinder that's all. This kit looked cool, and I thought I'd try it. So far so good.
THanks for the comments guys.
