RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
MCD Jetpro Sidemount pipe
Old 02-28-2009, 02:58 PM
rc-martin
Default MCD Jetpro Sidemount pipe
Hi all, I recently purchased a jetpro side mount exhaust for my MCD Baja 1000. A lot of sites (DDM included) list these pipes as fitting all off road MCD vehicles. They don't. []
My Baja 1000 is the first edition type with the flat disk wheels and the roll bar is different to the later EVO models, it is wider and therefore the exhaust fouls and won't fit.
looks like i'm going to have to get an EVO type roll bar to get it to fit, which is another £30 []
Old 02-28-2009, 03:48 PM
dgav407
Default RE: MCD Jetpro Sidemount pipe
You can probably make the later style (Evo) centre roll bar yourself.
I recall seeing lengths of the alloy pipe at Homebase (or B&Q) for a few GB pounds - they also had a cheap pipe bender.
Clive
Old 03-01-2009, 02:34 AM
rc-martin
ORIGINAL: dgav407
Clive
I might give this a try. I'm not sure how the roll bar mounts on the evo though. I can see it is screwed through the bottom of the chassis but don't know if it is screwed straight into the roll bar or onto a post screwed to the chassis.
Old 03-02-2009, 09:08 AM
dgav407
There are plastic posts/inserts that are bolted to the chassis and the roll bar is held in place on the posts with one tiny screw on each end.
http://www.mogatech.de/shop/index.php?a=3667
Clive
Old 03-02-2009, 04:01 PM
rc-martin
Cheers Clive, i actually bought some alu pipe and a bender and made my own. I cut the unused roll bar mounts from the front of my car and used these to mount the new one. It fits a treat.
Old 03-02-2009, 04:42 PM
killermolly
My Feedback: (25)
looks nice
Old 03-02-2009, 04:54 PM
dgav407
Great work - out of interest where did you get the pipe from?
Clive
Old 03-02-2009, 05:08 PM
rc-martin
ORIGINAL: dgav407
Clive
i got it from B&Q like you suggested, was about £5 for a metre length and the bender was £18. Still cheaper than buying new from MCD and i've got loads of other stuff i can use the bender for.
Martin.
Old 03-02-2009, 05:17 PM
dgav407
Thanks for the info.
Clive
