How much power 1/5 scale vs 1/8 scale
NJ
Hey, i was wondering how much power these big 1/5 scale cars have. I have a 1/8 Sportwerks Mayhem that can easily get to 50mph pretty quick, but do these regular 2 stroke engines have more power than a small nitro engine. So what is faster. 1/5 scale or 1/8 scale.
RE: How much power 1/5 scale vs 1/8 scale
I have to say that if you compare engines, the 1/5 scales engines have more power. As far as speed, there are 1/5 scales that do about 30 MPH to some that top out at over 80 MPH
IN
ORIGINAL: Dirtdigger04
here's a stock 5t speed attained.
1/5 scale is also lot better handling than 1/8 mt flips alot..
1/5 scale can power thru terrain that would stop any smale scale car. bigger car, bigger engine,more torque!as for horsepower some of the nitro motors can put out some big numbers but torque is what you drive!
ORIGINAL: quarterscalelegends
a side by side race the nitro will win hands down. [:-]
ORIGINAL: speedy.d
Just what is 2.5ft-lbf when comparing that to nitro engines?
1ft-lbf is 192in-oz!
So, a nitro engine that peaks out at 50in-oz (typical for an RTR nitro .28ci engine) is barely making more than only ONE FORTH of a whole ft-lbf.
So, the 6-7hp gasser making about 2.5ft-lbf is making 480in-oz!
Gassers make so much torque we have to use much higher gear ratios to tame that torque: something like 8:1 where nitros have really deep gear ratios, like 14:1 or much deeper.
MI
torque- this baja weighs 27lbs.. think a .28 can do this?
http://www.youtube.com/watch?v=9dLjSl0KeSM
LA
Its pretty hysterical how my 1/5 jumps out of the hole. A 25lb. monster truck that will outright smoke the tires off the rear... C'mon! You know that'll get anyone to grin. The torque is UNREAL. It does right at 50mph. However, it takes a few seconds to get there. It is, after all, a monster truck. But besides the fact my 1/5 will roll over my 1/10 and keep truckin like theres no tomorrow, the thing handles way better on the track than my 1/10. Perhaps it's the weight issue and b/c the 1/10 is way lighter, and therefore less stable at high speeds. Now as far as who would win in an all out concrete drag race, or course the 1/10 nitro. The acceleration is gonna be way higher and be able to get to top speed much faster. But, I would have to say 1/5's are a BLAST. If I had to, I'd sell my 1/10 long before my gasser went.
Towards the end of this vid a Baja and a Hyper 8 have a drag
Gives you an idea of the acceleration differences.
[youtube]http://www.youtube.com/watch?v=bQOIZYc3fHY[/youtube]
From my experiences 1/8 nitros with good engines will run rings around any 1/5th scale, even with a top of the line package. They just don't have the power to weight ratio.
No doubt nitros are faster in every way, it's simple power to weight as Coopz said. Having said that though, it's a whole different ball game a 15kilo truck going 50 mph. Large scale is more fun and more rewarding, you need better driving technique as well.
ON, CANADA
Power and speed are 2 different things. It's all in relation to it's size, hp, gearing and weight. I can say that 80% or more of those who try gassers end up switching over from nitro. I did this over 5 years ago and never looked back.
Plus at less than $0.50 in fuel to run for 40 minutes non stop why would you not love it!
GA
ORIGINAL: savagecommander
GA
ORIGINAL: SELWA
ORIGINAL: 46u
Other then fuel 1/5 scales are MUCH more expensive!!!!!! My race Savage I have some where around $1,500 in it and when I am done with mt HPI Baja 5B SS I will have around `$3,000 in it. [X(]
ORIGINAL: SELWA
My Feedback: (45)
GA
ORIGINAL: 46u
Sure can all day long with out having to find a bump to get the front end off the ground. The recorded for nitro is 109 MPH. I like my gasser but will NEVER give up my nitro. It is like compering oranges to apples.
ORIGINAL: 46u
1/8 versus 1/5 is beyond comparasion in my opinion,the whole impression with 1/5 with that roaring,deep sound,the weight and the appearance is absolutely unbeatable compared to the little nitrobee zumming aroundThat is my opinion
GA
ORIGINAL: Bmr4life
No you can't. The point of their statement was that a .28 does not have enough power to pop a wheelie in a 27lb vehicle.
ORIGINAL: 46u
GA
I think some of the price has to do with the fact of supply and demand. There are a WHOLE lot more people into nitro then 1/5 scale. Like I said I like my 1/5 5B SS a lot but will never give up my nitro's . Nitro are much more durable and you can jump them a WHOLE lot higher with out damage.
ORIGINAL: Coopz
ORIGINAL: 46u
NJ
ORIGINAL: Coopz
Yea, but that Baja looks like and sounds like, a pig.
I have 3 large scales in my stable that would have ripped that rice burner up.
I'm not saying they are the fastest, but that for sure was no good of an example.
GA
ORIGINAL: Pro5thScaleDistributors
ORIGINAL: Coopz
