Baja 5B question
GA
RE: Baja 5B question
Check to make sure but the only difference I think is the hook up on the carburetor.
http://www.davesmotors.com/s.nl/c.88...t.A/id.4467/.f
Yes, well pointed out savagecommander. While they are the same TYPE of engine, the HPI branded 'Fuelies', are CY engines. They are not as good as the real Zenoahs, but are still good engines. Once you start adding ported headkits etc, they begin to equalise. In my own personal opinion, for all round use, low end and top end, a stock Zenoah G260RC with a torquey pipe is pretty hard to beat unless you are prepared to spend a lot more money on professional porting jobs etc, and guess what engine is used for most of those pro porting jobs? That's right, the Zen.
