slawhammer
LA
slawhammer
had a change of heart went with the o'neill bro's race ported 290 engine 28.5cc jetpro pipe and the other stuff i mention what you thing also added outterwears starter cover we do not bash these truck we drag race them
RE: slawhammer
O'Neail make a good engine....If your drag racing ..you still may want to do the chassie mod for rear end flex....
I would say look in to a 2spd and gear changing....Use wheel adapters for the rear axles....Fg to Baja.....Ram-tech works very well.....DDM has those...
go with baja wheels and get some tarmac tires for asphalt or cement.......if you run on a dirt strip get Hostile AT tires..for the baja wheel...you will need foam incerts for the tires as well
you still may want to get a pico modified kill switch..I would recomend that........Slawhammer
