Stock Exhaust
RE: Stock Exhaust
Standard exhaust like on an FG or a clone or what. It wouldn't be that hard to do if you can weld it back together.
My opinion would be to get a tuned pipe. I'm just new so not an expert yet. I have just fitted a dominator pipe to my Carson Comanche and the motor seems to rev a bit more freely but I haven't driven it yet. I have also fitted an O'neill brothers reed block. Don't really know to much about it yet but it seems to have made the motor crisper as it prevents double fueling.
RE: Stock Exhaust
its the Stock exhaust for a Rampage witch is the same exhaust as the baja 5b stock, i hear of people doing this all the time. but the only way I see to do it is, to just break up the inside with a screw driver and dump it out one of the ports
RE: Stock Exhaust
I dunno. The screw driver method seems a bit agricultural but whatever works I suppose. I would cut the seems and split it, gut it then weld it back together. This might be like running no muffler though and cause engine damage??? They need some sort of back pressure to run right. From what I know about motorbikes, no muffler can burn the piston out but that's on four strokes. I assume two strokes would be the same. This is the best place to find stuff like this out as most here seem real helpful and have been playing with 1/5 scale stuff for ages.
