2 cycle engine oil
2 cycle engine oil
i've recently purchased a kingsmotor 1/5 29cc and is eager to get this badboy up and running
earlier i went to autozone and o'reiley to pick up 2 cycle engine oil but i wasn't able to find Klotz or Amsoil so instead i got the Vavoline multi-purpose 2 cycle engine oil, after doing a little search i've found out i should be using klotz or Amsoil, so guys which autopartstore or where's a place to buy klotz synthetic? and what's the bestmixing method"as in what do iuse to measure"
and the bad news is that im totally new to this so is there anything in particular that i need to look out "check" before starting up my toy for the first time?
one last thing, i need to change out my throttle servo horn, on the instruction it said to turn on my transmitter n than the reciever align it side way *==== ( * represent the screw & = represent the plastic piece) and tighten the screw.is this the right way to do it?
OH
RE: 2 cycle engine oil
Set about a month aside and read this
http://www.rcuniverse.com/forum/m_7249314/tm.htm
As far as the 2 cycle oil, you will be fine with what you have bought.
Klotz is good cos of the added caster oil , but i want to try blue marble next time .but any high grade synthetic 2stroke is good, just dont use the lawnmower brands of 2stroke oil , use the motorbike 2stroke stuff
My Feedback: (7)
ORIGINAL: splcrazy
i'm just wondering why you say this.
CA
I am kind of ashamed to admit this, but I am using outboard 2 cycle oil from WalMart. The only reason I am using it is that is what I had the day I got my baja, and I have 5 gallons of gas mixed with it.
I do know the difference because I have a quart of BlueMarble on the work bench ready to go, but I just cannot bring myself to throw the other gas out. Even with the walmart outboard oil, the engine runs great and after 2 and 1/2 gallons, there is no sign of anything going wrong.
I will say, however, if I get a new engine, that will be started the first time with Blue Marble and NO outboard oil.
Dennis
ORIGINAL: fourwheels0
why not use the lawnmower stuff?. do you mean weedeater oil?. if 2 stroke weedeater oil is fine for my weedeater and chainsaw then it should be fine for these.
ORIGINAL: splcrazy
I think he's trying to say that the lawn mover stuff won't burn as well as "special" oils but if you get the mix right, it will do fine. You can get the best oil at the wrong mix and it wont burn right. I run go kart oil by silkolene. I think it comes down to "you get what you pay for" in one sense but some oils will gunk up a plug even at the correct mix. That's what is important, having enough but not too much. Start with the recommended mix and experiment from there, mix small batches (saves stuffing up 5 litres of juice and having to get the calculator out to fix it) and don't stray too for off the recommend ratio in one go. ie recomends 30:1 try 28 or 32. You want to see a little bit of smoke all the time through the rev range. As always, please tell me if anybody thinks this is wrong.
Most run a 25:1 mix, I personally run 32:1.
For most purposes, 25:1 is a good ratio. Get the mix cup from DDM and you will always get a precise ratio
http://www.davesmotors.com/s.nl/c.88...t.A/id.3350/.f
I use Amsoil 100:1 synthetic oil for my pocket bike engines. But I use 2 packets per gallon of fuel. For some reason, using one packet I couldn't get the engine to start. I drained the tank and added a second packet and it fired up fine. I'm sure there was a carb tuning issue too using 100:1
Banned
My Feedback: (7)
how whould you know what i'm using?.
weedeater engines are weedeater engines they all rev about the same. there is much less load on a weedeater than our buggys so they should rev even higher than the buggys.
this is what i'm using.
5.2 oz per gallon.
so far no problems.
5.2 oz per gallon.
so far no problems.
ORIGINAL: jpilkinton
5.2 oz per gallon.
so far no problems.
5.2 oz per gallon.
so far no problems.
Who makes PRO-MIX might sell the same stuff to Amsoil or KLOTZ????? How do we know?
I think you can get away with weedeater/ chainsaw mix if your engine isn't modified, and you dont hold the throttle wide open for too long . If your engine has been pushed to the limit, with a pipe, porting etc, then you would want a higher quality oil.
Im currently running 2-stroke chainsaw oil in my zenoah and had no problems...
In the end, if you don't have the oil/gas ratio correct and the tuning is set too lean it wont matter what oil your using...your engine is still going to wear out prematurely.
ORIGINAL: sam123
I think you can get away with weedeater/ chainsaw mix if your engine isn't modified, and you donthold the throttle wide open for too long. If your engine has been pushed to the limit, with a pipe, porting etc, then you would want a higher quality oil.
Im currently running 2-strokechainsaw oil in my zenoah and had no problems...
In the end, if you don't have the oil/gas ratio correct and the tuning isset too lean it wont matter what oil your using...your engine is still going to wear out prematurely.
