changing the brakes on my FS racing MT
ON, CANADA
Just noticed that my brakes are no longer as quick as they used to be. I wanted to either tighten them or change them, but I am not sure what I have to remove to get at the brakes on the FS Racing monster truck. Also, is the a disc brake system out there for the FS MT or can one be fitted to work on the FS MT? I desperately need more stopping power for my beast.
Thanks for any help you can give me.
ON, CANADA
RE: changing the brakes on my FS racing MT
It is the FS Racing Monster Truck (MCD clone). rear brakes because it is 2wd. but curious about front disc brakes if possible
Yeap, more than possible. Easy. They are the same as FG monster truck, Carson Comanche(mine) and Smartech.......um.......not the traveller.....um
Talking front brakes.
Rear info next.
Rear info next.
ON, CANADA
not yet, I am used to my 1/8 nitro buggy, have never done anything on this beast yet other than change motor, pipe and steering servo. dumb question, but were is the collets on the brake rod?
I'm not sure about the correct terminolgy for these bits but here goes.
The bar that runs from the accelerator/brake servo ,to the braking cam, which operates the brakes, should have a piece of soft tube on it then a locking ring/collet sort of arrangement right at the end of it, at the rear of the car?
I'd take a pic to show you but my batteries are flat.
