RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
carb issues....wt 603......
Reply
Old 05-26-2009, 09:03 AM
bajamaniac69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default carb issues....wt 603......
Hey guys
...........my truck has a 603 carb.new............ran good and strong on friday..............went to gas it up yesterday...did so...but now when Igive it gas ...........it bogs...bad............does not get to full throttle RPMwise....bogs real bad carb opens all the way judging by the butterfly next to Han Lneedles...car is set to 1.25 on low and 1.5 on high side ...idles great but when Iget on the gas bogs alot .....?????????????????
not running in dirt ...on tarmac......cylinder bolts are tight....manifold bolts the same...gas is the same as Iwas using on friday.......
Any ideas???
bajamaniac69 is offline
Old 05-26-2009, 09:07 AM
RCguru09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: carb issues....wt 603......
A air leak around the carb. Check the carb gaskets. I suspect the primer gasket under the primer bulb. That's the first place to check.
RCguru09 is offline
Old 05-26-2009, 09:10 AM
bajamaniac69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
brand new carb and gaskets...............
I switched the old 668 to 603 ....was running great ..........filled it up ...now bogging on ..........not getting up to rpm's needed ...you think it would still be the gaskets??
sprayed wd-40 on carb area......with filter on .............no changes in idle at all..............idles perfect .............
?????? confused
thanks
Old 05-27-2009, 09:28 AM
RCguru09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The problem is usually around the carb. Check everything. It could be the intake gasket??? Bogging is a sign of a air leak somewhere??? It dosen't take much. Check the fuel line to the tank and fuel filter too.
RCguru09 is offline
Old 05-27-2009, 10:47 AM
savagecommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no no, 1.5 on the high might be too much gas. try leaning out the high speed, see if you get more rpm's. an indication of an airleak is an erratic idle and will most often be located by wd-40.
savagecommander is offline
Old 05-27-2009, 12:40 PM
bajamaniac69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ITS WEIRD......I AM AT 1.5 ON HSN.......IF I RICHEN IT UP ......PLUG STAYS DRY ...ALMOST CARMEL LIGHT BROWN.....VERY LIGHT LIGHT GREY ......NOT OILY OR DARK...
LIKE I SAID EARLIER ...SPRAYED ALL AROUND CARB ,MANIFOLD ...NEAR BOTTOM OF THE JUG NEAR GASKET (COPPER ONE)....NO CHANGES IN IDLE AT ALL TO SIGNIFY AN AIRLEAK.....i PULLED THE HSN AND LSN OUT ALL THE WAY .....SPRAYED A LITTLE CARB CLEANER...NEW CARB NOT EVEN A 1/2 TANK THRU IT ...NO MORE BOGG JUST WORRIED THAT IT WILL NOT RICHEN UP AT ALL AT 2 FULL TURNS ON THE HSN...IS A ONEILLS 28.8 PORTED HEAD ......
COULD THIS LEANER EFFECT BE A BAD CARB????
THANKS
Old 05-28-2009, 08:57 AM
RCguru09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had th same problem and it was bogging as soon as I gave it gas. NO erratic idle. I found out it was a bad gasket. Not even WD-40 found it. The primer gasket. You had a air leak somewhere and by checking everything again you probably fixed it if you removd the carb and checked it. 1-3/4 on the high is ok. You can try checking the filter screen to ake sure it's new.
RCguru09 is offline
Reply
Display Modes
