Baja 5B fan protection
Engine fan covers, I'm aware of the outerwares for the pull start. Does anyone have a product for the inboard side?
My fan fragged and I'm guessing it's due to debris. It must have happened at high RPM because it blew a hole through the fan housing and engine housing.
My Feedback: (13)
RE: Baja 5B fan protection
check out slammer dams at ddm .it wraps around the inner part of the engine.or u can use the coffee filter cut into pieces and glued around the openings of the inside.
WA
this is the Sammer dams.
http://www.davesmotors.com/s.nl/c.88...t.A/id.6155/.f
WI
ORIGINAL: frumpy
Here is a new product from Outerwares
That outwears one looks like it would keep out more debri then the other one. I seen that other material in rolls sold @ menards for 15.00
CT
ORIGINAL: hndaman1
ORIGINAL: frumpy
A couple of strips of velcro and you're good to go Matt
