Need Help Locating 48T Steel Replacement Spur Gear for FG MT5 2-Speed Transmission!
My Feedback: (22)
TX
Hi Guys,
My son and I need some help in locating a 48T steel replacement spur gear for my FG MT5 Monster Truck! This weekend we just smooth stripped out the plastic high side gears coming off a small jump! I have the CY 29cc motor with a Jetro tuned pipe and I think it just has too much torque for the plastic gears! I have located the 16T and 18T pinion gears and the 46T spur gear, but have not been able to locate the 48T spur gear for the FG 2-Speed transmission #7451 (Was originally looking for a 44T steel spur gear, but was advised to go with a different set of gears!)! I would consider a new or used set of steel replacement gears or just a new or used 48T steel spur gear! I would sure appreciate any help you guys might be able to give us in locating this spur gear or set of steel gears! Thanks.
Richard
Richard
RE: Need Help Locating 48T Steel Replacement Spur Gear for FG MT5 2-Speed Transmission!
Have you hit up Large Scale RC? They carry CAT% MFG gears, all steel, and those are great
http://www.largescalerc.com/index.as...TS&Category=66
I am not sure if there are any steel 44T gears, I have only seen 46T ones. But maybe in Europe, they might have some steel 44T for FGs.
Check out Hobbythek and thumb through their pages
http://www.rc-car-online.de/htstarteng.htm
My Feedback: (22)
TX
Savage Jim,
Thank you for the response! However, I did try largescalerc.com and bigboytoysandhobbies.com also, with no luck!
Richard
Richard
Sorry I couldndt give you a definitive location, I thumbed through other sites as well and the smallest spur gear I could find for FGs are 46 steel.
My Feedback: (22)
TX
Thanks guys for your suggestions! By the way I live in Houston, Texas! I did try Big Boy Toys and Hobbies and they were out of stock also. I have located and bought the three other gears, an 18T steel pinion gear (#6432/01), a 16T pinion gear (#6431) and a CAT5 46T steel spur gear that is supposed to work on the 2-speed transmission, according to both Large Scale RC and Big Boy Toys and Hobbies! Apparently the company that used to make the 44T spur gear for the 2-speed tranmission was Crazy Nuts Racing out of California, but they quit making them about two years ago. So, I have been advised to go with a different set of gears, so maybe someone that might know where I can get a 48T steel spur gear or might have a used 48T spur gear left over! I will probably have to get the plastic one (#6052/01) and take it to a machine shop and have them make me one out of steel! But that could turn out to be very expensive!! I am still hoping for someone here to be able to lead me to one!
Richard
Richard
I remember Crazy Nut Racing, I always had my eye on them even while I was saving hard to buy my first 5th scale. I never knew they made a steel 44T spur; I'm actually disappointed I never saw them [:@]
Ow well. I think I will try to build a speed machine one day like those Florida guys, a 44T spur with high tooth count pinion will be a good first step in that direction. I think I will look for a Marder, probably used, because I'm in the midst of saving up for an Elcon.
I think I can upgrade a Marder and slap on a 44T spur and to get a good gearing to reach 60MPH (hopefully more). This spur coupled to a 26T pinion on the high gear might get a good top speed.
Yeah, did you just get that or are you teasing me and in reality yuou had that from when they used to make those?
My Feedback: (25)
IL
ORIGINAL: SAVAGEJIM
My Feedback: (22)
TX
Fernando,
I sent you a PM! Also, check your email! I will take it! How much? Send me your PayPal email address with the price! Thanks.
Richard
Richard
