Homemade monster servos
#126
RE: Homemade monster servos
ORIGINAL: krakkah
Hi there, very interesting thread, I am also a novice to electronics, I was wondering if it matters if the servo is digital or analogue??
analogue servos are usually transistor driven so both sides of the bridge are open at center..... if you make an external h bridge from mosfets, then all mosfets will open... making a loud POP and release that mysterious smoke lol
then again some circuits have found away around them
im testing this one and so far so good
http://www.cadvision.com/blanchas/he.../h-bridge2.gif
and thats using an analouge servo...
heres a vid of some chap who is using the same circuit
http://www.youtube.com/watch?v=FWJL1...layer_embedded
#128
Is that Syntax from Ozlargescale?
And who is the guy in Australia he's building 10 boards for?!??!!? [sm=50_50.gif]
#130
hello, thank you for trhe info Maori
i consulted a friend that works for general electric who asked a friend to explain the schematic to him, heres what he emailed me
another friend suggested j1 and j2 are normal switches to maybe flip the values on the table in the schematic, i guess for polarity.
i put in an order for double parts, im going to build 2 of these on one board, its for a much bigger project
thanks again, will certainly report back and give credit
cheers
seesoe
In the circuit, the transistors act as switches changing the signal from high to low and vice-versa. So, if there is a high signal on A, it will become low atQ1because the BJT is grounded. This will then create a high on the gate of the MOSFET shown at Q2. It's a p-channel MOSFET and needs a high to turn on. This puts 12V through the MOSFET. This voltage will create a positive voltage at R13 and turn the green LED on. It will also create a positive voltage at the M1 node and turn the motor on. The signal will go through the motor and ground the other side through Q4, which is an N-channel MOSFET.The opposite occurs at node B. This needs to be a low, and it will make Q5 high. A low will appear at the Q6 gate and negative voltage will appear at the LEDs. It looks like C and D aren't really needed since the SPDT switches could just be hooked up at position 3. Not entirely sure why you would need them unless you wanted to drive the transistors as explained in the fourth note under the schematic
cheers
seesoe
#132
just an interesting link, thought id share
also check out the rest of the site, he has bigger open source h bridges with info on how to make them.
http://www.rediculouslygoodlooking.c...lawnmower.html
cheers
seesoe
cheers
seesoe
#133
this way looks fairly simply... its only 3-4amps but that might be ok....
its a bit hard to read the english translation but ya get the jist of it
http://www.quickest-owl.com/tutorial/giant%20servo.pdf
#134
time to kick this into life again
getting a couple of these
http://www.pololu.com/catalog/product/1393
they "should" be hook it up and go circuits!!!!!
although its $99us, it should be a crap load more powerfull than a Tonegawa.. and with 12amp cont and 30peak, its more than enough
OR
its baby sister
http://www.pololu.com/catalog/product/1392
they appear to be the same type of board but only capable of 3amps.....( a wiper motor will proably be more than this
however with a simple external Hbridge employing 4 mosfets (maybe $3 each) on the output should raise its power capabilities to what ever mosfets you use...
being alot cheaper it may work
if anyone can see a reason why these wont work PLEASE inform us before i folk out $250us on these
i will also try working on a 6volt servo using a 14.4volt cordless drill. (they are quiet powerfull when you hook up 6 volt direct to the motor)
stay tuned but as always, please dont hold ya breath lol
OR
its baby sister
#136
I am still interested in building one of these. I'm a mechanical guru, I feel like a complete dummy when it comes to electronics. I it would be nice to have something like this for my 1/4 scale RC tank
[link=http://rckingtiger.weebly.com/]http://rckingtiger.weebly.com/[/link]
I'm so close to giving up and going with a different system. My main advantage is that I absolutely dont need anything that makes very fine proportional movement. Since the steering is controlled by braking either side of a differential I need a simple on/off circuit. To avoid over stressing the wiper motor when it reaches the point where it has applied full brakes to said side. I am thinking of using a NO/NC switch so instead of the motor trying to keep turning, the circuit will kinda bounce between on/off/on/off/on This will still keep the brakes locked and when I release the steering a spring will slowly return the arm on the wiper motor to a neutral position. I hope everyone understands what I'm talking about.
Anyway I'm still expecting to fry a wiper motor every now and then. But since these come from a car that is a dime a dozen at the wreckers I'm not so worried about it.
#137
ORIGINAL: Dirty_Vinylpusher
What happened to the boards that swedish bloke was making for you?
so oh well back to the drawing board
#138
another board
http://www.robotpower.com/products/simple-h_info.html
25amps!!!!!!!!
however this board will need a hacked servo to provide feedback...
25amps!!!!!!!!
#140
well thanks to the help of a friend, we finally got the wiper motor servo going.... and going well i might add
we used this board
which only handles 3 amps... so we built and added a simple hbridge costing around about $7 on the output.. now it can handle 20 odd amps
board costs $50us,
there is a board that handles 12 amps but its $100..... so a $50 board with a $7 part to handle 2x what the $100 board can do...... makes sense i think
how ever..... the boards need to be programed (set up rather) via a pc program downloadable for free.... so if ya not computer programing savy, then ya probably better off getting a programmer to do it... apparently it was quite simple though so i guess most programmers could do it
heres a vid
http://s9.photobucket.com/albums/a60...eringservo.mp4
ill go into more detail about hooking it up later...
plus ive been working on a 6volt system that is far more simple ....not as accurate but still strong...
we used this board
board costs $50us,
heres a vid
#141
#143
Hi guys ,I'm new to this forum but I know of a servo motor source that may be of intrest for mid to large scale projects. Yamaha, on some of their Two stroke motorcycles in the mid 80's to 90's used servo motors to drive the powervalves in the engine via pull pull cable setup. they are a proper striaght gear multiple reduction unit, and quite sizeable (approx. 4 inches ) with an inbuilt 7.5k ohm feed back pot. there are no electronics in the unit, just a 5 wire connector coming out of it , 3 for the pot and 2 to the motor. I think there is a seperate control box under the seat that would contain the H bridge which interfaces to the ignition box so the powervalves rise with revs. Being that it is yamaha and designed to withstand 2 stroke motorcycle use it would be a high quality unit, that being said the price of a new one would probably kill you, maybe from a m/cycle wrecker though ? Anyway the bikes in question that I know used them are : RZ250 and 350, WR 200, DT 200 and DT 230. The RZ ones may be bigger as they drive powervalves in 2 cylinders ( have an RZ I haven't actually seen the other ones, just know they exist ). They would be great for rudder control in large scale planes or boats as they are already set up for cable control. Anyway I hope this info may be helpful to someone. I have a very large scale project going on at the moment, setting up a manual gearbox racecar for a kid without legs to race speedway ! lol Need servos on the clutch and gearbox. Now theres an intresting challenge.Watching your developments with intrest. Good luck.
#144
Just a quick note, another 2 good places for electronics and componentry in Aust. are RS electronics (RadioSpares, they are worldwide, out of UK I think) and WES Components. (Wagner Electronic Services, out of Sydney). I deal with WES regularly, they have heaps of components, and cheap but no data, you have to know what you want.
#146
Not quite as simple as that.
(wish it was)
You've gotta build a so called H-Bridge to go between the original servo and the wiper motor to handle the power of 12V.
I'm slowly getting the hang of what that all means but haven't attempted making one yet.
(wish it was)
#148
Ive been researching the same thing, I had a circuit working well using an Oatly Electronics kit which is no longer made unfortunatly,
I got everything working using some power seat motors, they even had the pot intergrated with the motor so no messy extra arms to drive the pot, only thing is the final test I reverse polaritied....... and [&o] the circuit
Vantec now make a plug and play solution now for $79.95 US
http://www.vantec.com/servocat.html
Worth a shot for those not electronically inclined
Nick
Nick
#150
Hi Guys, I've read a fair chunck of this thread - yes, even the negative stuff. A couple of things, first of all I'm a racer that uses shop bought stuff so I'd probably never need to make anything electrical other than a loom.
You servo build....
What sort of car are you using this in?
I'm assuming it's for the steering, do you need so much torque from a wiper motor and will the advantage of this home build balance out with the heavy battery you'll have to use to power it?
Have considered using an electric window motor as most of them are smaller?
I can't see any of the videos or some of the photos as I'm at work.
You servo build....
