Thunderbolt II Pro Race Buggy Build
#51
RE: Thunderbolt II Pro Race Buggy Build
Pwaicon, I like the TB2 and all but your TT still kicks its @$$ IMO.
Id like to pickup one of these Pro versions, but having 3 Ramps as it is......Its not going to happen (read: wife aggro)
#52
GA
ORIGINAL: pwaicon
I usually use the Elcon clutch in all my cars, which is also a four shoe adjustable clutch, but I picked up the Lauterbacher one as it was on sale as part of DDM Thanksgiving sale. The clutch should be here Thursday so I should get it installed on Friday, which will give me time to paint the body.
Yes I know about the Elcon clutch. From everything I have read the Elcon and Lauterbacher 4 shoe are about the best you can get. The new style Lauterbacher not so sure about as I have read very mixed emotions about it and most are not good. All so it is way expensive and to adjust it you have to disassemble every thing. Not like the older model or the Elcon where all you need to do is drill a small hole in the clutch housing.
The only problem I have read about the Elcon clutch is the older ones can with shoes that where not real good but newer ones with the white shoes are fine. All so I heard about the weak plate on them which they made a up dated plate to fix this problem. Some say you need the plate and others say you do not. On the Elcon I can only go by what I have read.
I will never I mean NEVER go back to the stock style clutches after running my Lauterbacher!!!!!!!!!! It hooks up so I mean SO much better then the stock clutch ever did. I like it so much in my HPI 5b SS I got one for my TBII PR!!!! Many claim that on the CY engines they all so cause premature bearing failure as they are not balanced like the Elcon and Lauterbacher.
#53
Banned
yeah i would really love to try a lauterbaucher 3 shoe over the stock clutch to see the differnce.
that now and even better diff on my beetle then i would be in buisness.
keep it coming lads.
these nutech pics are awesome!
#54
GA
ORIGINAL: dc2 man
these nutech pics are awesome! [img][/img]
http://www.davesmotors.com/s.nl/c.88...t.A/id.2423/.f
DDM has the 3 shoe with alloy shoes on clearance.
http://www.davesmotors.com/s.nl/c.88...t.A/id.2420/.f
#56
GA
This is the NEW Lauterbaucher 3 shoe but I have read a lot of people are not happy with it and a FEW are. All so to adjust it you have to take the vehicle part where you can get to the face of the clutch, has a special tool and cost much more the the clutches that have proven there worth.
http://www.davesmotors.com/s.nl/c.88...t.A/id.6429/.f
Adjusting tool
http://www.davesmotors.com/s.nl/c.88...t.A/id.6519/.f
Adjusting tool
#57
ORIGINAL: STEVE MARSHALL
Hey Pwaicon, great thread. I have a TBII rtr, std version. This thread of yours will help me alot for up grades. lasst weekend my rear diff let go. And the plastic servo saver. but when i pulled down the diff i found one side gear striped out and crown wheel marks on the chassis, also a little damage to the crownwheel where the pinion has jumped. i have the plastic inner diff housing. and the plastic outer housing.
Greetings Maik
#58
GA
asphaltcowboy are you talking about the diff cups or the diff housing. STEVE MARSHALL yes I defiantly recommend going to the alloy diff cups.
#59
I think Mike is talking about going alum alloy for both the diff cup and the housing that holds the diff assembly.
I know that is what I would do if I had the option.
#60
GA
The TBII Pro Racer comes with the alloy diff cups and plastic diff housings just like my HPI Baja 5b SS. I do not have my TBII Pro Racer running yet but on my 5b SS do not see the need for alloy diff housings or in the case of the baja transmission housing as the diff and trans housing is all in one. I do see where the alloy diff cups are necessary do to flex. HPI found this out the hard way just like on the Savage. Nutech does have some left over alloy diff housing from Smartech but people have had problems with them. Nutech is going to make some up dated ones sometime. Bottom line he needs to get the diff cups for now.
#61
ORIGINAL: SAVAGEJIM
Yes, that´s what i mean ...
Greetings Maik
#62
GA
ORIGINAL: asphaltcowboy
Greetings Maik
ORIGINAL: SAVAGEJIM
Greetings Maik
#63
BC, CANADA
the new off road laut 3 shoe has proved to be junk for off road use[&:], eats up shoes in a tank or so...been a few reviews and a lot of returns to DDM...maybe ok for onroad but offroad just get the 4 shoe, as 46u says drill a hole in the clutch bell to adjust it in place...shoes are hard wearing and you get zero fade as things heat up... but i found...as with any clutch..sand is an enemy...not for wear but for messing up the engagement point...i went back to an unvented bell on my rampage and will keep the unvented on my Nutech just to keep the crap out...
i wont use any other clutch after running one of these
#64
ORIGINAL: 46u
But then, I admit, I only have run one with at most a 26cc engine. I do not know how it will hold up to stress loadings from the torque of a modded and performace piped engine with monster torque.
As for Nutech, from what Moo mentioned earlier, it sounds like that Chris is serious about making sure the factory uses the correct materials and will never settle for less. I commend him on this and for ensureing a great performance product hits the market that is on par with the european RC quality. There are way too many RC sellers who will settle to sell the compromised and weaker product, but even in this testing pre-market phase, it is clear that Chris is serious about upholding quality and hammering down on the factories to maintain it.
#65
GA
ORIGINAL: SAVAGEJIM
I guess that you are right about the stock HPI 5B diff housing holding up; I have yet to see one give out from flexure. And looking at the shape, despite it being no thicker than say an FG plastic diff housing, HPI looking like they did their elemental stress loading research pretty well. The angles of the HPI gear case looks very sound and not prone to flexure (or at least allow only minimal flexure).
ORIGINAL: 46u
Now on the TBII PR I will find out as when I get mine running which I hope before the 19 as there is a race then.
#66
CA
#67
CA
ORIGINAL: Obeast44
#68
CA
I finished most of the build today; it’s actually 1 AM here so technically I finished most of the build yesterday. I am still waiting on my clutch but I installed the engine anyway just to make sure there weren’t going to be any issues with the pipe install.
#69
CA
I also received Nutech’s alloy air filter, which I think should perform fine if oiled properly. On a groomed track I also think it should last awhile before the elements need changing, in really dusty conditions that might not be the case.
#70
CA
Last set of pics for know. I also get to try out the Nutech tuned pipe, I am very curious to see of this pipe performs.
#72
Hey guyes, i can't find any reason for the diff to fail, I think the shimming may have been a bit on the low side and a bit of flex in the housing and it was game over. Also i have a small amount of damage to the crownwheel, looks like that skipped at some stage too. PSR here in oz are getting in both housings in alloy very soon so i will be upgrading and filling with oil as well. I also have that pipe on mine, seems to have better off the mark power and sounds alot better than the can.
Steve
Steve
#73
So whats the cost on the Pro version again?? I have a spare DS/Sikk 27.2 and with LargescaleRCs event coming up in June. I might have enough time to snag one and set it up by then.
#74
GA
ORIGINAL: Obeast44
pwaicon I see you are going to do like I and try the stock exhaust to begin with. I finished getting my engine ready last night and hopefully my last order will be here today.
#75
ORIGINAL: 46u
At the moment the TBII PR is not available only to testers and racers. The estimated street cost is going to be around. $1,350 US plus or minus. Not sure I am going to make it but hoping to go to LargescaleRC race in June as it is right around my birthday.
Haha JK, never even raced em before hehe.
Pwaicon is it me or does it seem like the "hornet" type pips would fit on these with very little modification?
