SY Racing 4WD Reverse :-) Picture Heavy
I just took on some samples of the SY Racing 4WD MT so far I am very impressed with everything I havent ran it yet but as I do I will keep posting on here, for now I have some pictures right out of the box, these come with the 26cc CY engines and 2.4 Radio.
Reverse System
Steel Gears Stock
I should have some video up soon its 10 degrees right now with below zero wind chills so this should be a good test for it
Thank You,
Scott
Zero Gravity RC
Reverse System
Steel Gears Stock
Thank You,
Scott
Zero Gravity RC
RE: SY Racing 4WD Reverse :-) Picture Heavy
Yes the 3rd servo is for the reverse, you activate it from the transmitter and the servo arm pushes the reverse button and when you want to go back forward you just hit the button again from what I can see as I haven't ran it yet, or you might need to hold it in for reverse and once you let off it goes back in to forward, I will know more once I get a chance to run it . As far as I know these are not clones as I haven't seen anything like this yet with reverse and 4wd so I am pretty excited, the buggy I haven't been able to find anything that looks like it either so as far as I know these are SY Racing models and not clones, now I am not an expert on all of the Gas RC models out on the market but from what I can see these are unique and something different. I am really impressed with the size and thickness of all the plastics and control arms twice as thick as the FS product and the bodies are almost twice as thick as the FS bodies .
I will have more info as soon as I run it along with some video but from what I can see so far these will be superior to the FS that I have dealt with.
Thank You,
Scott
Zero Gravity RC
Thank You,
Scott
Zero Gravity RC
NY
Looks like it's built quite well. Thats the one thing I was hoping for as well, I like the idea of reverse, kind of important to me, with something in the large scale size. The body and rims are a bit ugly for my taste, otherwise inside it looks really nice.
ORIGINAL: Soloratov
Thank You,
Scott
Zero Gravity RC
Sure glad I didnt take on a container load yet lol [:@] got my first 1/2 tank through and melted the front differential box, back to the drawing board and see what we cant come up with from the factory but I will not import and distribute these until I feel they are up to par, I just hope the factory is willing to make some changes and acknowledge the issue, rear differential is fine I don't know if the plastic differential box failed or if the inner bearing gernaded first and then took the box out, I am sending the pictures back to the factory and see what we can get done, I really like this truck and the reverse is hands down the best lol, I had it plowed into a huge snow bank all the way at the end of our parking lot anything else and I would have had to walk all the way across the parking lot to turn it around but with the reverse I just pushed the switch and it hold the servo arm against the actuator and when you want to go back forward just push the button on the transmitter again and the servo arms goes back to neutral :-) dam thing goes just as fast in reverse as it does in forward lol very cool feature just need to work out the bugs.
I will report back once I hear from the factory!!!
Thank You,
Scott
Zero Gravity RC
Thank You,
Scott
Zero Gravity RC
Banned
man i like the reverse feature also but on my nitros all of them it was a real pain to keep running.
maybe this features a better system,i would like to see how it holds up.
i wouldnt be too hard on the car over the diff breking this could be an assembly glitch you may have just got one bad one out of a bundle.
it looks strong too,the diff gears look good.
let us know how you get on.
Looks like a bearing failure to me, their bearing supplier mightve had a bad day
The differential gears look good and im realling liking the removable cups on the diff outputs.
Yes I to am very impressed with the quality and I hope it is a fluke but its my only sample of the MT so I need to know this is not an issue, I will be getting new bearings from the factory and a differential box as everything else looks fine, I to think the bearing gernaded first and took the cases out but its hard to tell, the plastic cases could have been a bad mold to which would put a ton of pressure on the bearing, I will know once I hear back from the factory as I really want to make a go of these because it really is a quality built unit, I know there is a weak point in all of these but I need to know there will be support from the factory with issues like this so this will be a big test, hey everything happens for a reason I just hope we can get through this little snag. Everything else was hands down twice the quality of the FS and the FS is the only other product I personally imported, all of the fasteners on these are alan heads and unlike the FS fasteners I haven't stripped out any of the heads taking them out so that's a bonus. everything on this truck is so thick and well built I was really not expecting this but that's why you take samples and work out the bugs :-).
I have high hopes this little issue will get resolved and I can continue on with importing these because they really are a great unit every where else thus far, the transmitters are great no range issues or glitches like the FS transmitters, and I cant say enough about the reverse lol its great and so simple it hurts haha I cant believe non of the other manufactures jumped on that band wagon yet.
The whole roll cage is solid billet aluminum its not hollow lots of roll over protection unlike the thin hollow ones that wad up in the first roll over lol!!
I will report back once I get it back up and running, I could always put it back together and run it in 2wd which I will more than likely do until I get the replacement parts from the factory, so stay tuned I will have some video soon.
P.S the CY 26cc is a great running motor tons of power for stock cant wait to get it broken in and put a pipe on it and get it all tuned in lots of potential :-)
Scott
Zero Gravity RC
Scott
Zero Gravity RC
From what I have been learning ,it seems to me that bearings are a real problem in the Chinese cars.
Zero- you are very impressive, this industry does not have many venders that would post up the carnage on a new vehicle. It sounds as though you are really trying to put quality in the peoples hands without pulling the wool over their eyes.
BC, CANADA
Send one to me to test...I think my reputation preceeds me as a no mercy basher
I like the look of this, looks pretty stout and drivetrain looks solid...with obeast on the removable diff cups..nice touch...not sure on the reverse though...I need something that gets it back on it's wheels not goes backwards...lol...how much does it weigh? i reckon weight is the key factor with all these new trucks coming out...light weight= less breakage in cartwheels/rollovers etc
the cy 26 makes great power it sure moves the nutuch along at a gallop...looking forward to some hard bashing video
Banned
MOO
i have to agree with you on cy engines,they have got a lot of criticism from people and many dont like them..
me,i only had one in my GT5-R from nutech a 23cc and man was it a ROCKET.......
i find cys have a wicked off the line bite......
not to mention strong super hard clutches
ORIGINAL: heliyeahman
ORIGINAL: EngageRC
The one tested here is the lower cost version.
the bearing of the new version are upgraded.
is a matter of $
is a matter of $
Now back to the important stuff
ORIGINAL: mooman007uk
ORIGINAL: FShopups
yea scott is the real deal, atleast he tests them before selling a product...a real asset to the business..
Now its time to tear my other sample apart for parts so I can get a tank through this and start to beat the ever living you know what out of it to see if and where the weak links are :-) thanks guys I will will keep you posted!
P.S the factory emailed back and they are sending out some new bearings and differential case so far I am really impressed with there service which is just as important as the quality of there product to me
Thank You,
Scott
Zero Gravity RC
Here are the wheel hubs and square drives, they are nice and thick :-) shouldnt have to worry about rounding off the square drive on the back of the wheels these are deep and thick I like this setup. Wheel bearings all seem nice I had to replace alot of those on the FS before I shipped them out 90% of them were shot right out of the box I had to spin the wheels on all the vehicles I shipped to ensure the wheel bearings were good most of them I had to replace before I shipped them out wtih the setup they had there was alot of stress and pressure on the inside bearings.
Thank You,
Scott
Zero Gravity RC
Thank You,
Scott
Zero Gravity RC
BC, CANADA
same tires (different wheels) as the nutech MMT, i'd still like to see some reinforcement rings around those wheel squares just to make sure the plastic doesn't split
ORIGINAL: No Moa
Truck looks good, body looks terrible. I don't understand why companys build a great buggy, and put such a crappy body on it.
Here is your body less buggy
Thank You,
Scott
Zero Gravity RC
Well I put the beast back together in 2wd until I could get the replacement parts from the factory, dam things really tears ass but surprise the same thing happened to the rear differential lol [:@] now I am out of parts haha I will have to wait and see if the new bearings and cases fix this issue, this is almost more fun in 2wd tachs right up on the dry pavement and smokes the rear tires doing donuts
I hope I can work out these issues with the factory this thing is a blast to drive and I cant say enough about the power, this thing stock has more grunt and topend then my FS MT with a tuned pipes, air filter and V Stack way more power.
Thank You,
Scott
Zero Gravity RC
Thank You,
Scott
Zero Gravity RC
