Rovan Sports Baja 29cc report
#51
RE: Rovan Sports Baja 29cc report
ORIGINAL: Kostenko
Hi Rallyfinnen,
I've been reading your experience with your Rovan Baja and i see that the quality hasn't approved since i bought two of the 5T's.
Well hold your breath because KM isn't all that either.
Hi Rallyfinnen,
From what I heard about KM, the plastics are better (some claim comparable to HPI), and there is a major difference in the flexibility and feel of the KM arms I received.
For instance the Diffbox doesn't have two bearings on the layshaft but just one bearing with a plastic ring and rubber ring on the other side.
Then i replaced that two rings for a bearing and that problem was solved,
With one bearing in each end of the shaft, there can be no binding/strange loads on the bearings when the chassis is flexing during jumps etc. A lot of force could be applied to the gear-case with three bearings if the chassis is flexing. Given the strenght of the Rovan plastics, I want to avoid this.. Well, I might be wrong..
However I replaced the seal with an old crank seal I had lying around to keep the dirt out.
going to the diff and i noticed the dogpins were not easy to move around?
When i tried to check...the screw in the dogpin was damaged so i could't get it out but i'm sure there's a rubber ring instead of a bearing underneath there as well.
Replaced it for a hpi diff and everything is running like a charm.
When I assembled the diff I might have tightened the screws too much, because two of the flages on the diff house came straigh off.. Another alternative is that the material sucks..
I ordered a KM diff housing.. maybe that also needs to be tightened using fingertips only..?
Did nobody notice that the KM baja's are so light? Well its because you can bend some alu parts so easy it looks like butter alu.
When you want to create a baja with some KM parts its possible but don't take all parts..is my opinion.
KM and colors, ow boy it must be hard to get all wheel hex hubs in one orange bucket because i got serveral light tanned wheel hex hubs with poor color.
And many other parts were also different in color and that doesn't look very nice.
When there out of some colors its mixing time and you get a nice bag of purple, orange and grey.
I never tried the engines because of my history with the Rovan engines, so i stick to CY engines all the way as far it goes for a lower budget baja.
I have it apart, and the machining/plating seems a bit funny on the upper edge of the transfers, but in general it looks lika any chineese rip-off engine.. not perfect but useable
What problems have you experienced with the Rovan engines?
I ordered the KM engine case and fan cover to replace the broken Rovan case (was not sure the Rovan and KM halves would mate, so I ordered both KM halves)
Hope that will work..
#52
I was allready warned about the Rovan engines on several forums.
So i toke CY engines from Taiwan which are also used on every HPI baja and just called Fuelie.
Km plastics are supposed to be better then Rovan and most people can confirm this.
And quality from KM alu is not so good if you can bend these parts so easy?
Or is it my strength that is way out of limits
#53
I'm sure you're right about the KM alu.
I have not found the info about the Rovan engines, could you maybe post a link where I can find a summary of the engine problems?
Maybe also good to have everything collected in this thread as a reference to those seeking info about Rovan's.
And, by the way, is this a problem with all versions of the engines?
#54
I gave my Rovan heaps of running over the weekend and have had NONE of the problems others seem to experience. All my orange bits match in colour, none of the plastic parts seem brittle, the aluminium parts seem as hard as a rock, and the Rovan engine does a great job.
Please don't get sucked in to replacing parts which work perfectly just because others have experienced problems. Only replace stuff when it lets you down. Life becomes much easier then!
#56
ORIGINAL: tonystott
#57
Do you have a Rovan Johnny?
Kostenko,
I would also like to see links to where problems have been reported regarding Rovan motors.
I think we have to separate the horrendous problems experienced by the owner of the thread, as that motor damage is way beyond a QC issue. I am reminded about the Jaguar owner in UK who spent ages trying to track down a mysterious rattle, and eventually (I seem to recall) the factory gave him a new one, and then dismantled the noisy one. Eventually they found, inside the door sill, a nut welded to a thin piece of wire, which banged when ever the car hit the slightest bump. Beside it was a note: "you found it then" (or similar). Some b*stard worker's idea of a joke, or he was somehow p!ssed off at his bosses...
Kostenko,
#58
ORIGINAL: tonystott
Kostenko,
I think we have to separate the horrendous problems experienced by the owner of the thread, as that motor damage is way beyond a QC issue. I am reminded about the Jaguar owner in UK who spent ages trying to track down a mysterious rattle, and eventually (I seem to recall) the factory gave him a new one, and then dismantled the noisy one. Eventually they found, inside the door sill, a nut welded to a thin piece of wire, which banged when ever the car hit the slightest bump. Beside it was a note: ''you found it then'' (or similar). Some b*stard worker's idea of a joke, or he was somehow p!ssed off at his bosses...
Kostenko,
#59
ORIGINAL: tonystott
I'm not the type that replaces stuff just for fun or bling, but if I think I see a weak spot while the car is in pieces I try to fix it instead of waiting unil it breaks. Usually one failure leads to other parts breaking too.. A clutch holder made of brittle plastic is a thing that might cause a nice chain reaction in broken parts (clutch, clutch bell, gears etc and even a bent crank and blown piston in worst case -I've seen that happen) so I decided to replace it with the KM alu part since that was so cheap, and I was ordering from the KM supplier anyway.
Since the engine is apart, I'm also curious if there are any known weak spots that I sould have a closer look at.
I have a FS buggy too, and that one had a lot of issues to be sorted out, so I have learned the hard way!
But that's another story, let's try to stick to the Rovan bajas in this thread
#60
My Feedback: (9)
PA
ORIGINAL: Rallyfinnen
The car came straight from the manufacturer in China, I doubt they sell clones of their own stuff
I'm shocked with the quality of the plastic, I definitely expected better based on what i read about these cars on different forums.
As said above, the plastic is very light, hard and brittle. Nothing like I've ever seen on a LS car before.
I wonder how they get the ball in the wishbone unless they mold it around the ball
I have sent a long email to Rovan today with a lot of pics etc. I hope they can send me parts with better quality.
I might end up buying better quality plastics to be able to use the car.
#61
I still have no updates about my car, still in pieces waiting for shock pistons (no clicks in the Rovan adjustables, and the stop is broken in at least one of them, so I ordered HPI adjustable pistons instead).
I replaced the broken Rovan crank case with a KM case, and that had two small shaft seals, so I'm also waiting for another small shaft seal before I can start the engine.
My brother has still not received his Rovan that he ordered almost 2 months ago.
He has been in contact with Lily, and she says they will return the money as soon as they have confirmed (something, don't know what) with EMS who is shipping the car. I think he will be happier without it..
He's looking at getting a HPI SS from the US instead, since prices over there are around 50% compared to Europe!
#62
#63
Time for another update..
I ran the Rovan once in the snow (and nothing broke! ), but decided 4wd is the way to go as long as there is snow. So I have been running my FS instead, and that works perfectly in the snow! (finally got all the bugs fixed on that clone)
I will post an update later when the snow is gone and I get a chance to see what the Rovan can do.
My brothers experience with Rovan is another disaster, the car has not arrived, and he has not been refunded either! (he ordered it in the end of November if I remember correctly)
I found a good deal on a MCD here: http://www.mogatech.de/shop/index.php?a=4127〈=eng
So I ordered that one (figured the offer won't last long), and I will sell it to him when/if he gets his money back from Rovan so he can afford it. He has a good engine & radio that he can use, so I only ordered the rolling chassis. Worst case, I have to keep the MCD myself
#64
To finish the story about my brothers order, he got his money back last week for the car that was never delivered. So, I guess for him it was a lucky ending even if it took some time (three months from order).
Hopefully I can do some driving with my rovan soon, when the snow and ice has melted away. I've been able to squeeze 3,5kw out of the rovan 29cc engine on the dyno this far, but now the main bearings need to be replaced.
#65
I have now driven the Rovan for the first time. I was filming a lot, but most of the time the mini-camera was covered, so i was just leftf with a short clip to post.
The end result after driving abt 30min was a broken rear rim, leaking shocks and a damaged shock-shaft. No major crashes, the rim was definitely 'over sensitive'. On teh shock shaft the crome plating was coming off.. I sanded it down and will try to use it again..
Here s the short video(boring footage, I know..):
http://www.youtube.com/watch?v=unFPgMoaQuQ
#66
Just a small update here again.
I have done a few short drives with the rovan now. I have broken all the rovan rims by now (in abt 60min of driving), upper front wishbone, front support for roll-cage, a couple of beadlocks (when rims broke). I have been gradually replacing them with KM parts, and none of the KM plastic parts have broken while the rovan parts kept breaking. The cylinder on the 29cc also split in two pieces, i think i widened the intake a bit too much..
Here is a video from a short test (not with the rovan engine though):
http://www.youtube.com/watch?v=1rE8Mr7TeBQ
#67
geez, the rovan plastics really are brittle, broken rim from a couple tumbles,
the stock width baja rolls over alot, i have fitted a set of darksoul type axle extenders to mine,
they widen the baja by about an inch all round and makes a huge difference to the stability,
your engine is making good power, what pipe you running?
#68
I modified the Rovan pipe, made it shorter and smoothed out the transition between header and dffuser cone, made a huge diffrence in power/power band. (graph below)
I'm thinking about widening it too. It got better when I softened the shocks and lowered it a bit though.
Here is another video ending with some more broken plastic:
http://www.youtube.com/watch?v=bCZEiZyqt7o
#69
MN
Um, yeah... for you guys complaining about the suspension arms, go here and solve the problem once and for all: http://rpmrcproducts.com/products/HPI/5BParts.htm
#71
I see what you mean about shortening the rovan pipe,
the rovan pipe normally extends beyond the rear wing, above the rollcage before bending into the expansion chamber,
having shortened the header the pipe now it is re-routed under the rollcage and tucks in behind the rear shock?
this is how my km baja rear pipe fits.
#75
Look dan dry your eyes,
don`t threaten me or anyone on here.
you spam the ****e out of this place and id say alot of people are about fed up with you.
