RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Bob Stormer, scratch built Monster Project.
Reply
Old 01-25-2010, 07:23 PM
  #101
Bob-Stormer
Bob-Stormer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Stormer, scratch built Monster Project.
Front cantilever mounts and arm. I incorporated the curve on the rear shock mount into the front cantilevers. I think it added some appeal and tied in the shape to the rest of the chassis.
ID:	1364512   Click image for larger version
ID:	1364513   Click image for larger version
ID:	1364514   Click image for larger version
Bob-Stormer is offline
Old 01-25-2010, 07:29 PM
  #102
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: quarterscalelegends
are you doing mig or tig with this project?
On this, 99% TIG, using MIG to do a quick tack where needed, then take it to the bench and TIG it. I prefer TIG, but it's a lot slower to do, and you can't use magnets to hold stuff together like MIG. Makes it a lot harder to do things in a hurry. I love the speed of MIG.
Old 01-25-2010, 07:31 PM
  #103
quarterscalelegends
quarterscalelegends's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am just learning to tig. I have a mig as well. I am much better at the mig, but cant get the welds small enough to look good on 1/4 scale RC car frames, so i moved to tig. I bought a miller diversion and have been happy with it.
quarterscalelegends is offline
Old 01-25-2010, 07:40 PM
  #104
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, perfect example of where TIG shines. Small welds. Perfect example is the ti-rods and pushrods on this project... I welded a 3/16 nut to a tube without deforming the threads. No other way to pull that off. Well, maybe braze... but I bet it would find it's way into the threads, and I wouldn't expect it to hold up.
If you're into quarter scale, you need to learn TIG, metal and aluminum. You could do it with MIG and smaller wire, using more of a stitch technique, still probably get the job done just fine. But you don't get that butter and stack of dimes that we all dig.
ID:	1364520   Click image for larger version
ID:	1364521   Click image for larger version
ID:	1364522   Click image for larger version
Old 01-25-2010, 07:44 PM
  #105
quarterscalelegends
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yep, thats what i am trying to do. I think my major hangup so far has been that i start the heat out slow and then heat it up to a puddle. I need to just jam it down, get the puddle and let off the pedal as needed. I have been sitting there waaaay too long, but I am progressing. Just need more sit down time. tough to go around corners too, like on tubing.
Old 01-25-2010, 07:59 PM
  #106
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep. Hard to get over that hump of worry. You get all that time into something you don't want to ruin it.
Old 01-25-2010, 08:18 PM
  #107
troppo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All it takes is time and practice mate, be patient and have faith in yourself.Bobs work is top notch but he`s got the time under his belt.
I`ve seen some of your work on your forum and you have the talent to master this.....
troppo is offline
Old 01-26-2010, 12:30 PM
  #108
Lars from Norway
Lars from Norway's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A perfect TIG-weld is sexI have tried it a bit,but i have used MIG the most.Worked as a welder for a while making hulls(mainly the frames on the sides of the hull making the shape,i only remember the norwegian name )
Lars from Norway is offline
Old 01-26-2010, 01:44 PM
  #109
Sherv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally someone with welding skills making a home made vehicle... Turkey **** Welds make me a Sad Panda.
Sherv is offline
Old 01-27-2010, 02:15 AM
  #110
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Front lower suspension arms.
You can see a before and after on what I had to add.
Had to modify the existing lower arms to accommodate the pushrod for the cantilever and incorporate some adjustment. And it's a good thing too, with the curve we put on the cantilever I gained mechanical advantage I didn't want so the lower pushrod mount is all the way out on the arm when I wanted it in the center. It's about .75 further out than I figured, but still good. A thicker spring or one more set of holes on the cantilever arm about .75-1" further up should do it. OR, a 500 pound spring in place of the 400 pound unit. Travel is excellent, the feeling is excellent.
Video of the movement, first test, left side.
[youtube]http://www.youtube.com/watch?v=HkA3i_3BHGw[/youtube]
ID:	1365484   Click image for larger version
ID:	1365485   Click image for larger version
Old 01-27-2010, 02:19 AM
  #111
Dirty_Vinylpusher
Dirty_Vinylpusher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Sherv
Nobody is born with welding skills.
Some of us are still learning.
Dirty_Vinylpusher is offline
Old 01-27-2010, 02:37 AM
  #112
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Dirty_Vinylpusher
ORIGINAL: Sherv
That's a fact, and it takes time. I still consider myself a rookie or "weekend warrior", but I'm over the major hump. But I still learn every single time.
Old 01-27-2010, 04:05 AM
  #113
troppo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Bob-Stormer
ORIGINAL: Sherv
That's a fact, and it takes time. I still consider myself a rookie or ''weekend warrior'', but I'm over the major hump. But I still learn every single time.
Good words from both of you.
Not everyone has all the skills needed for this type of project, i have a small range of skills i am good at and a heap of things i`m willing to try but i`m not real good at.
Its the knockers (like sherv) that put a lot of people off trying to learn any new skills.
Some people cant weld, some can. Some folks can lay up fibre glass some cant. Dont knock people for having a go, encourage them.
If you cant say something constructive, shut the hell up...........................................
troppo is offline
Old 01-27-2010, 05:17 AM
  #114
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think he meant it as a compliment, no harm intended. And I like your refference to fiberglass.... MAN, I wish I possessed "ANY" skill in that area. Or with wood. I muddle through it and make it work, I'm sure it's painful to watch... ...lol...
I need to buckle down. This thing needs to be moving before this coming weekend is over (jan-30, 2010). I set a target date (for myself) of feb 5th. I have an RC race I want to unveil it at on the 6th. "Unveil"... probably not the right word. Simple fact is, I want to show it off a little. I've been busting my little hump on this, and I want to drive it.
And more importantly... start the next one, and it will be better, bigger, faster and jump higher. Kinda gives me goosebumps thinking about it. [sm=idea.gif] This project is what leads to the next project. Gotta start somewhere.
Old 01-27-2010, 06:00 AM
  #115
Sherv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it was a compliment. The Turkey poo welds were common thing on a forum i belonged to during the 2000s when I was active in the car modding community. I remember so many 1st gen Eclipse/Talon owners trying to do mods with some of the WORST welding I had EVER seen...
Sherv is offline
Old 01-27-2010, 06:53 AM
  #116
troppo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Sherv
Well i am sorry then, it just really bugs me when folks bag someone elses work, regardless of the standards.
If you can do better work you should offer advice not criticism.
Please dont take offence at my misplaced defence of 'shed' builders, i have a habit of jumping in with both feet when i should just stand back.
troppo is offline
Old 01-27-2010, 09:59 PM
  #117
Mudgy
Mudgy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
should see my bird poo when I use the stick!!
Oxy and mig I've learned, but geez it would be nice to have a tig. Are you listening Santa?
I'm gonna have to learn tig, too....the fella I knew who was good at it (used to run RALT Australia) has passed away.
I love your beads, Bob. Great Stuff.
Mudgy is offline
Old 01-28-2010, 04:28 AM
  #118
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Front suspension buttoned up, and on the ground testing.
I would consider the car a basic "roller". Needs LOT's of things still done. Cage made, body mounted, shocks re-done. front and rear bumpers and nerf bars made. Light bar made, electronics selected and mounted. Lot to do in the next 10 days.
[youtube]http://www.youtube.com/watch?v=UHgVoPXemlQ[/youtube]
#7, whole car movement.
[youtube]http://www.youtube.com/watch?v=X3-Y3MkBp4Q[/youtube]
#8, drop test, front suspension.
[youtube]http://www.youtube.com/watch?v=QX9sjrowXL0[/youtube]
ID:	1366264   Click image for larger version
ID:	1366265   Click image for larger version
ID:	1366266   Click image for larger version
ID:	1366267   Click image for larger version
ID:	1366268   Click image for larger version
ID:	1366269   Click image for larger version
ID:	1366270   Click image for larger version
Old 01-28-2010, 04:35 AM
  #119
Dirty_Vinylpusher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet machine!
Love the little crawler in the last pic.
"When I grow up I wanna be one of these"
But Bob, stop being Wilson from Home Improvements and show us your face
Old 01-28-2010, 04:40 AM
  #120
da mad maori
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice movement
your right its is alittle under sprung up thats no big drama....
coming along very nicely
da mad maori is offline
Old 01-28-2010, 04:49 AM
  #121
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet machine!
And ruin a perfectly fun build thread with THAT!!!
I put the crawler in there for a sense of size. The little crawler is a 1/10th scale 2.2" tire crawler I welded up out of aluminum about 2 years back. been a good little truck, wheelbase is about an inch to long, gets hung more than say a stock Axial would. But I like the look of it with the primer'd fender and LONG rear shocks. That was a fun build as well.
We scratch built a vintage dragster last winter for a buddy of mine. I make a quick cameo in the video at about 47 seconds. ...lol... Maybe turn your speakers down a bit.
[youtube]http://www.youtube.com/watch?v=ANaS8ZBUKXQ[/youtube]
Old 01-28-2010, 04:55 AM
  #122
Dirty_Vinylpusher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HAHAHAHHAHAHAHAA
Quick cameo alright!
Cracked me up.
Oh and maybe you should put a LOUD VIDEO WARNING in that post in huge letters.
I had my speakers on 1 and it nearly blew them off the desk.[:@]
Sweet motor though.
Old 01-28-2010, 05:52 AM
  #123
Bob-Stormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I laid out some junk on the floor... Hmmm, maybe a road racer next.
Old 01-28-2010, 06:19 AM
  #124
Dirty_Vinylpusher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah..... just move that battery and electric motor a bit to the left.......out of the shot preferably....[sm=75_75.gif]
....and then sliiiiiiiiide that beast of a chop saw in to the middle between the wheels. [sm=lol.gif][sm=lol.gif][sm=lol.gif]
Old 01-28-2010, 07:54 AM
  #125
Frederik_b
Frederik_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fixed for you DV sorry for the poor attempt at mspaint hahah
Frederik_b is offline
Contact Us Archive Advertising Cookie Policy
