My Trevor Simpson Motor
These are pictures of my motor that I'll be running this year at the "Brooklyn Drag Club" in New York City. It has a 21,000 "High Voltage" ignition system on it for that extra spark and power. Like I need anymore than that. Also it has a special aluminum lightweight clutch shoes from "TMR Performance" that weight 73 grams with the spring, that equals a really high stall. Also the special billet flywheel that only weight .271 pounds vs a stock zenoah flywheel at .658 pounds
RE: My Trevor Simpson Motor
Don't know as of yet because I just got the engine back from "OBR Racing" and I installed the "High Voltage" kit on it this afternoon. It should be a real monster. Here is alittle information about the ignition.
The MSD Kicker Ignition designed for Go-Peds® and Go-Quads is the latest addition to MSD's full line of ignition systems. The Kicker Ignition comes with the same proud racing heritage that all MSD products are born with - tough, durable, accurate. On a Go-Ped® there's lots of banging around & vibration - our Kicker Ignition is built to take it and still deliver a hot spark! The MSD CDI box is completely sealed and potted with a high density ResTech Polyurethane Potting Compound. This makes sure that the internal components are protected from all the hazards that riding a 'ped can throw at it: vibration, water, dirt, fuel, etc.. The Kicker Ignition makes timing a lot easier, and a lot more accurate than the stock coil/pickup. You can control the retard rate from 1/2° per 1,000 rpm up to 1° per 1, 000 rpm with a simple timing adjustment screw on the MSD CDI box. Add the MSD Billet Aluminum Flywheel, and you'll have the most complete ignition set-up ever available for Go-Peds! With the MSD Kicker Ignition's hot spark, and adjustable timing, your Go- Ped or Go-Quad will really move out ahead of your competition. The "Kicker System puts out 21,000 volts that equals power[8D]
Thank You! bbuzzard. By the way, this engine is going in a FG Marder that will probably weight by the time I'm finished 17-18 pounds. I'm pretty sure with this set-up in a lightweight FG with a 2 speed, should be nuts[X(] OH yeah! it has a "Radical Ported" new 36mm Zenaoh cylinder from O'neil Brothers[>:]
Thats the MSD Billet flywheel that is a optional part for the MSD Kicker System. It only weights .271 pounds vs a lightweight zenoah flywheel at .678 pounds
