' Project' Quarterscale Blown HEMI..
IN
Hey guy's... Just thought i would stop in and inform you on the blown HEMI engine project I've been designing for nearly 7 years.. off and on.. mostly off.. lol.. anyhow I'll update this tread on it once i get more done on it... However.. I do have a few altered teaser shots of it for you 1/4 scale guys to check out... I altered these shots for a few reasons.. sorry guys... I 'll be posting s few videos as well as a ton of Non-altered pics on it once it's completed.. I should have the prototype model done within a few months or soo... It's going to be a beast boys... and i do mean beast...it will weigh in at nearly 12 lbs and will produce around 32 HP.... http://www.quarterscaleprostreetbere...lown-HEMI.html
Later
Stoney
Later
Stoney
BC, CANADA
RE: ' Project' Quarterscale Blown HEMI..
[sm=tongue_smile.gif] that is awesome even though it's hard to see...your link doesn't work...is it a gasser or nitro?
IN
Yeah i know the link doesn't work here... WHY.. who knows.. just go to my home page and click on the link there...
The HEMI will run on alcohol,,
Hemispherical combustion chamber, 3 angle valve seat, 0.5 intake, 0.435 exhaust, 19.5.1 compression.
Hemispherical pistons, 1.0625 bore, 0.9165 stroke
Solid lifters
2.70625 deck block
57.5* 60* 0.1625 blower cam
Just to name a few specs guys... I'll be creating a complete specs as well as flow chart on it within a few months... I apologize for the altered pics... I'm currently designing a custom watermark for my pics... once i get it done I'll post them for you all to check out...
Thanks for the compliments guys..
Later
Stoney
Solid lifters
2.70625 deck block
Later
Stoney
IN
Well i received the pistons/rods/valves/valve retainers/rocker arm shafts/rockers/pushrods/ pushrod guide & cups from being heat treated yesterday so i should have at least one set of heads assembled within a few days or soo.. I'll take some highly detailed shots of them then. I've also got the watermark done for them soo they will be clear... here are a few altered shots...
BTW... the head in this shot is scrap... That's why it looks so rough... I had a boo boo while face milling it... woops....
Amazing man, but can you take better pics they are just a little whited out.
My big inquisition is: are you actually going to run it for more the 20 seconds at a time? Or be like every one ells and through it on the shelf and talk about it? LOL
Now, now....I hope you don't mean we're crapping on about shelf queens
I will be running, just as soon as I am sure nothing will stuff up.
like other home builders, we take the time to make sure all is good, as there are no off the shelf spares if something was to go pear shaped.
If you build it, they will come
we're in a different predicament to multinational companies with bucks to throw around, and production schedules to meet, and staff on hand to resolve problems in team environments.
Patience my friend
BTW, Stoney, 32 BHP = Beast in anyones language mate[8D]
Patience my friend
ORIGINAL: Mudgy
Patience my friend
Patience my friend
ORIGINAL: jigawatt
The images are negated... you've got pm, so you can see what is REALLY in the pics...
IN
Guys the pics will soon be watermarked and posted... The pics are inverted colors.. Not negated... LOL..
Not to worry Mudgy... It happens!
IN
i finally got around to start the machining process on the blower pulleys... I've got the top pulley cut and face milled. I'm going to locate the center and bore it to the desired specs next, I will then drill the 6 mounting holes.. I'll post additional pics as i progress on them..
ORIGINAL: QSPSB2
IN
Actually if you take a closer look at my recent images you can clearly see i inserted a Copyright logo in place of the .com within my watermark..
Well i did manage to get the crank pulley machined as well... I'll attempt to bore them and drill the mounting holes next weekend hopefully... Once i get that step done I'm going to face mill them once again... most likely with the fly cutter...
I'll update this tread next weekend folks!
ORIGINAL: QSPSB2
IN
Thanks!
Yes i plan on running it... I also plan on producing a few different styles of the hemi.. Blown, Non-Blown, Tunnel Ram.. Etc Etc... I am also working on a small block design... It will be called mighty mouse.. LOL... I've been working on these designs for about 7 years on and off... unfortunately i just have much free time these days to work on them like i would like to... This quarterscale hobby is last on my list to do as far as that goes... I also have a real drag racing car I'm working on and had hoped to have it ready for this season... But once again.. Don't have the free time to work on it as i would like to either.
Once i get the first engine built I'm going to be doing allot of testing on it. I will also be taking quite a few videos of it on the engine stand as well as in the Beretta... And last but not least... YES.. I will be running the engine longer than 10 seconds like you see in some of these 1/4 scale engine videos out there... I would love to have the time to build a miniature dyno for my testing... But that ain't going to happen!!
Thanks again
Stoney
Thanks again
Stoney
ORIGINAL: QSPSB2
Thanks!
Thanks again
Stoney
Thanks!
Thanks again
Stoney
It makes me excited that you will be ruining it for more the 10 seconds at a time. LOL I can't wait to see it when it is done.
IN
Thanks guys... Well i still haven't got around to machining the centers on the pulleys yet... I ordered a new 6'' H/V rotary table to do jobs like this on... so once i get it and get it all set up I'll Get errrr Done!!!
However.. I did manage to get the majority of the machine work done on the 1/4 scale wooden engine stand I'm designing... I plan on producing these in aluminum in the near future... My primary reason of building one from wood first was to make sure it looked the correct scale... As many of you know... There are some things that can't be scaled down by simply dividing the dimensions by 4.. But in my case that's actually what i did and the scale is right on the money... I scale it from the old engine stand in our old basement... I did put together a short video on it as well... Don't mind the audio editing guys,,, or should i say lack of..
I'll also put together a long version of it together with all the machining steps in a week or so...
http://www.youtube.com/user/QSPSB
Later
Stoney
Later
Stoney
IN
Well i took the time and put together a slide show on the engine stand... I'll be putting together a few videos on the aluminum machining process as soon as i get the new H/V rotary table.. I also need to purchase a hot booting fire wire card for this new computer before i can upload them... I haven't a clue how to install the 1394 fire wire software... Should be quite interesting..
http://www.youtube.com/user/QSPSB#p/f
Stoney
Stoney
