33kg servo any good ?
anyone used these servoe s ? are they good ?
http://cgi.ebay.com/33KG-High-torque...item20af119bc4
RE: 33kg servo any good ?
ORIGINAL: borley1863
Never heard of them, but they are analogue and plastic gear so wouldn`t hold out to much hope for them.
Guy
Guy
Hi Hitec MG5745 £45-£50 or MUltiplex Digi 4 £70-£100 the prices very alot on the Multiplex,the Hitec are cheaper but Multiplex give you a lifetime gaurantee.
Regards
Guy
Regards
Guy
Regards
Guy
Regards
Guy
Good to see you back !! I've had good luck with the bigger Hitec's .. 330 oz. Are these for your steering ? Wouldn't think you'd need a monster for the TF or FC. However, with all the work and investment, I would def go with a good brand name ALL METAL or TITANIUM geared servo for sure.
ORIGINAL: nomobux
ORIGINAL: kenazzo2000
which one s do you use i need one for steering one for mini moto disk brake and one for mini moto engine gas
ORIGINAL: nomobux
ORIGINAL: nomobux
Hitech 5955TG is what I have .. 330 oz I believe they recently came out as a new number. They are strong and pretty fast.
ORIGINAL: nomobux
ORIGINAL: mooman007uk
the digi 4 is now hitec 5755...same servo in a black case and $30 cheaper
BC, CANADA
for steering and brake probably the 5755 for the engine if it's just throttle you can use a regular size servo...anything digital will do the job as it doesn't need much ooomph
how big are the wheels you're using???
