Need Proline Excavator replacement screws size
Can anyone tell what are the screw size for Proline Excavator bead lock and where I can get some? Thanks in advance!!
BC, CANADA
RE: Need Proline Excavator replacement screws size
just checked my desparado rims and they're M3x12mm..if you're in a bind 5-40 should work too..slightly bigger and will retap the hole as you screw it in
